Author Topic: Trick to Getting the Seat On and Off?  (Read 587 times)
Online Sorg67
on: July 30, 2020, 09:43:17 PM
Is there are trick to getting the seat on and off?  I find it to be a real pain.  Usually takes a few minutes of frustrating fiddling.
Re: Trick to Getting the Seat On and Off?
Reply #1 on: July 30, 2020, 10:51:14 PM
Don't have any problem--but if I had a trick it would be to make sure the front is in position first
Offline Mister Paul
Reply #2 on: July 31, 2020, 08:17:01 AM
Yes, you need to get the front in the right place before you engage into the slots at the back of the seat. Then push down at the front and slide the seat forward until it clicks.
Reply #3 on: July 31, 2020, 08:19:53 AM
Yes, that's the trick, and yes, it's a pain.  :087:
Offline grumpyzuma
  • Bike: CB500X MY2018
Reply #4 on: July 31, 2020, 08:25:19 AM
+1...I thought it was just me being cack-handed, nice to see it's not just me! It does get easier with practice...usually!  :006:
Online Sorg67
Reply #5 on: July 31, 2020, 11:54:42 AM
Thanks for the tips.
Online HarrySeaward
Reply #6 on: August 01, 2020, 10:24:14 PM
I find that turning the key in the seat lock while you're installing the seat helps a whole lot. Until I figured that out, I would also take an embarrassing amount of time to get it on securely.
Online Sorg67
Reply #7 on: August 02, 2020, 11:21:49 AM
Much easier with tips.  Thanks again.
Online Jonathan
Reply #8 on: August 05, 2020, 04:47:32 PM
*Originally Posted by Sorg67 [+]
you need to physically bend the seat pan as you hook the front end in first. tap the back and it should click into place. It's the middle hooks that are the problem....do it a few times and you're sorted
Reply #9 on: August 05, 2020, 04:59:36 PM
You can also use a Dremel or similar to cut around a 1/4 off each of those plastic hooks half way along the seat, that way you can engage the front of the seat on the tank boss before the hooks connect with the loops on the frame, then when you slide the seat forward the hooks slide into the frame loops more easily.
