Author Topic: Wonít go into first gear  (Read 498 times)
Offline scott c
on: July 31, 2020, 09:12:17 PM
Sometimes bike wonít go into first gear so I either roll forward a little or hold gear lever down and release clutch a little til it goes into gear then pull clutch back in . I spoke to dealer and they tell me itís normal
Re: Wonít go into first gear
Reply #1 on: July 31, 2020, 09:28:41 PM
If it were normal I did not see that on Honda site when looking at the bike specs  !
I suspect we would all be suffering the same issue if it were normal.
Reply #2 on: July 31, 2020, 09:57:10 PM
If you want to shift back to first gear while stationary especially, if you try to achieve it from some higher gear is difficult. It is perfectly normal, caused by the way these gearboxes working. As you slow down shift back one by one, or if you have to do an emergency stop, and you're stuck in a higher gear do what you described - releasing and pulling the clutch, and potentially engaging and rolling the bike a bit.
Reply #3 on: July 31, 2020, 10:00:47 PM
I get it's normal to rock the bike back and forth sometimes..and especially if one has  not gone down the box when coming to a stop...but every time ?
Last Edit: July 31, 2020, 10:01:27 PM by Oyley
Reply #4 on: August 01, 2020, 08:38:29 AM
+1  - changing down multiple gears when stationary or very slow can need a slight release of the clutch.
Offline STOKIE
  • Bike: 2020 CB500X
Reply #5 on: August 01, 2020, 08:49:27 AM
Presuming the clutch is adjusted correctly?.
Offline scott c
Reply #6 on: August 01, 2020, 09:15:55 AM
I think so is there a procedure
Offline STOKIE
  • Bike: 2020 CB500X
Reply #7 on: August 01, 2020, 09:20:23 AM
Yes, check your workshop manual for clearances, slacken everything off adjust the lower (clutch end) first then handlebar end.  :028:
Reply #8 on: August 01, 2020, 09:36:50 AM
*Originally Posted by STOKIE [+]
+1  :028:
Reply #9 on: August 01, 2020, 04:21:43 PM
If you look at how the transmission works you will see that it is possible sometimes that you have to let the clutch out a bit or rock the bike to engage first -this is very true on the pre 2019-these transmissions are called constant mess not synchronized
