Author Topic: Tire pressure?  (Read 612 times)
Offline KennyV
Tire pressure?
on: August 27, 2020, 02:29:23 AM
My riding is a true 50/50 mix of gravel and pavement. My other bikes with tube tires I usually run a lower air pressure for the gravel. My 2020 500X is my first experience with tubeless tires and I'm wondering how low can I safely go with air pressure? I've  been experimenting lowering pressure down from the 29 / 41, I'm now down to 24 / 36.
71 Z50 Minitrail, 72 Yamaha RT2 360, 74 Yamaha DT250A, 20 CB500X
Re: Tire pressure?
Reply #1 on: August 27, 2020, 05:03:49 PM
Your good with those pressures-but don't forget with the skinny front tire if you lower it to much and hit a hole or good size bump you could bend the rim-seen it happen many time including myself
Offline KennyV
Re: Tire pressure?
Reply #2 on: August 27, 2020, 05:41:51 PM
Thank you, that's good information to keep in mind.
Online JMo
Re: Tire pressure?
Reply #3 on: August 27, 2020, 11:31:39 PM
If you're regularly riding on unsurfaced roads and trails, you'll benefit from lowering the rear further still to improve grip and traction...
for info. I run 28psi front and rear all the time (with TKC80 tyres) both on and off road/mixed terrain riding - maybe dropping them to 25psi if things are particularly soft or rocky.
I wouldn't go much below that (as Motorboy suggests) to protect your rims, and to keep tubeless tyres seated - certainly no lower than 20psi in that regard.
Offline Ponzan
  • Bike: 2017 CB500XA
  • Country: cl
Re: Tire pressure?
Reply #4 on: August 28, 2020, 12:38:47 AM
totally agree: 30-28psi all the time, sometimes as low as 25 at the rear. I learned it the hard way !!!!
Previous: NXR150, XRE300, DR400, XL500, scooters
Offline KennyV
Re: Tire pressure?
Reply #5 on: August 28, 2020, 01:07:31 AM
Thanks everyone for your thoughts and experience  :763: I think I'm going to leave the front at 24psi and my next ride drop the rear to 32psi.
Offline Superplasma
Re: Tire pressure?
Reply #6 on: September 24, 2020, 04:27:23 PM
+1, been there and done that.
Superplasmer
