Author Topic: Tire pressure?  (Read 1804 times)
Re: Tire pressure?
Reply #10 on: January 21, 2021, 10:34:19 PM
*Originally Posted by Advchic [+]
Thanks Motorboy, I’ll try a bit at a time.
As for the type of riding, winter forces me to stay on the pavement but that will change once spring and summer hit.
Currently running stock Dunlops and don’t foresee a change in the next while.
being I have the same tires I can tell you when reducing pressure for street use you will know when you go to far -handling goes to crap-radials need air to keep the side walls up
Offline Advchic
  • Bike: 2020 CB500X
Re: Tire pressure?
Reply #11 on: January 22, 2021, 03:28:30 AM
 :763:
Offline phattanglo
  • Bike: CB500X 2013
Re: Tire pressure?
Reply #12 on: January 22, 2021, 04:04:19 PM
Can I ask as a 100kg road only rider what the tyre pressures should be.
I'm still on the original Pirelli Scorpions
Last Edit: January 22, 2021, 04:06:08 PM by phattanglo
Re: Tire pressure?
Reply #13 on: January 23, 2021, 03:14:07 PM
*Originally Posted by phattanglo [+]
You are in the range of factory setting-check your manual
