Author Topic: engine buzz in 1st and 2nd gear  (Read 594 times)
Offline satsuma
  • Bike: 2016 CB500x
on: September 19, 2020, 10:37:15 AM
does anyone else experience the annoying buzz from the motor in first and second, from around 4~5k RPM up?
third gear and up are silky smooth.
i understand if its just a part of the little 500cc motor but i'd like to know if theres a way to cut it out.
i can hear it and feel it in the seat.
cheers.
Offline BZH
Re: engine buzz in 1st and 2nd gear
Reply #1 on: September 19, 2020, 12:45:36 PM
no feeling of extreme vibrations on the x.
Do you have a givi crash bar?
If so, it is possible that it is he who resonates around 4 or 5k.
If so, check the tightness of the crash bar bolts. You can also add a rubber washer for tightening.
Offline satsuma
  • Bike: 2016 CB500x
Reply #2 on: September 19, 2020, 12:54:15 PM
*Originally Posted by BZH [+]
I donít have them installed, Ďmais merci mecí
 :038:
Reply #3 on: September 19, 2020, 01:34:43 PM
5000rpm in 1st and 2nd gear seems fairly high revs - do you do that every time or just when getting away quickly?
I tend to 'short shift' in these early gears and let 3rd gear and up do the work.
Like BZH, I don't notice any bad vibes on the X, although some have mentioned vibration through the bars and pegs at 5-6000 revs, but usually this is in higher gears at, say, 70-80 or even 90mph.
2017-2019: 12000 miles recreational use - 89.73mpg UK; 74.72mpg US; 3.15litres/100km
Offline satsuma
  • Bike: 2016 CB500x
Reply #4 on: September 19, 2020, 01:42:05 PM
Iíve come from a sport bike background where I used run up the gears pretty high for the nice sound, haha. If you tend to short shift in the lower gears I will try doing that tomorrow. Havenít experienced any buzzing at higher speeds, but I tend to never speed more than 5mph over the limit, Iím still pretty apprehensive since I was hospitalised when someone pulled in front of me on said sport bike at around 40mph.
Thanks for your help :062:
Reply #5 on: September 19, 2020, 01:58:31 PM
When you read my comments about how I ride you must remember that I'm 67, and definitely slowing down!!  :008: :008: :008: :008:
Reply #6 on: September 19, 2020, 03:34:01 PM
there has been reports of a kind of uneasy at 5k going through the gears-my 2014 always did it-my 2019 did it for the first 5,000 miles than smoothed out
Offline satsuma
  • Bike: 2016 CB500x
Reply #7 on: September 21, 2020, 08:15:49 AM
i'm sitting at ~13,500kms, still happening. im just taking 1st and 2nd easy now and its not really a problem
Offline kmsz
  • Country: pe
Reply #8 on: September 30, 2020, 09:43:50 PM
This is something I noticed in my 2019 bike... between 102 - 106 km/h there are vibrations, above that they disappears. I had a Touratech windshield extension installed for better protection against the wind but the vibration in that speed range was so great, it sounded so strong that I had to remove it. I prefer a little more wind in the helmet to that crazy sound/vibration. Hopefully when I install my engine protector that resonance does not increase ...
Offline Neox
  • Bike: 2016 cb500x
Reply #9 on: September 30, 2020, 10:41:49 PM
When the engine is not hot enough near 5000 rpm and 100 km/h little buzz in the seat... like the old CB, but less stronger so more comfortable...
