Home
Search
Members Map
Photos Gallery
Login
Register
Forum Rules
Forum Help
Contact Us
Please
login
or
register
Honda CB500X
Main CB500X Boards
CB500X - General Chat
GIVI windscreen for CB500X
04 Mar 21, 03:11 AM
Pages:
1
2
3
Go Down
Author
Topic: GIVI windscreen for CB500X (Read 2736 times)
DthWsh
CB500X Member
Country:
Re: GIVI windscreen for CB500X
Reply #10 on:
October 27, 2020, 09:55:45 PM
I put on a Givi touring screen on my 2018. Lower spacer about 1 1/4 inches, top spacer about 3/4 inch. So the tilt is sharper than stock and the screen is moved forward a bit. I'm 5' 11 and have much quieter and smoother air, same slight cross-breeze but much better. No buffeting.
Logged
Flashp
CB500X Pro
Country:
Reply #11 on:
October 28, 2020, 02:29:30 PM
I've been through this and by and away the best solution for me was to cut down the original screen. Tried the Givi touring screen and it was just as bad but different if you see what I mean.
With a cut down screen the airflow is smooth and quiet...happy days.
I'm 6 foot tall in case that has any relevance.
Adjustable mount is this
https://www.aliexpress.com/item/4000417134409.html?spm=a2g0o.productlist.0.0.37eb6db7ikFeEk&algo_pvid=9cd374a9-e420-4618-9e31-39de3a2bc024&algo_expid=9cd374a9-e420-4618-9e31-39de3a2bc024-55&btsid=0b0a187b15929375630071786e3de6&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
Last Edit: October 28, 2020, 02:53:04 PM by Flashp
Logged
motorboy
CB500X God
Bike: 2019 CB500X
Country:
Reply #12 on:
October 28, 2020, 05:12:33 PM
What year is your bike and how much did you cut off
Logged
Flashp
CB500X Pro
Country:
Reply #13 on:
October 28, 2020, 05:42:37 PM
Originally Posted by
motorboy
It's a 2019 model, the screen is now 13 inches from the centre of the top edge to the tip on the bottom of the screen. I took several bites at it with a Dremel cutter designed for plastics, tried it out with each cut then when happy with it sanded with a block using decreasing grades of paper starting with 800 grit to get rid of the cutting marks then finishing with 3000 grade to polish the edge.
I now have mint condition Givi touring screen to sell that didn't work for me
Logged
motorboy
CB500X God
Bike: 2019 CB500X
Country:
Reply #14 on:
October 28, 2020, 06:31:47 PM
I think the 2013-2015 shield is about 13" tall so you ended up the same just alot cheaper
Logged
Flashp
CB500X Pro
Country:
Reply #15 on:
October 29, 2020, 09:28:26 AM
motorboy
I actually tried to fit a screen from the older bike. It fits in an approximate fashion and could be used, however, I noticed that that the fixing seats weren't flat against the mounting surface on the bike and I was concerned that the screen might crack so I never pursued it and returned it. But yes, it's a better height.
Logged
Emacs
CB500X Newbie
Country:
Reply #16 on:
October 29, 2020, 08:24:25 PM
I replaced the stock screen on my 2017 model, for a Puig 8901W Windscreen. Works great, for me @ 5ft 7". If I lift myself up a couple of inches I can feel the turbulence starting again. But in normal operation I can have the helmet visor up without issue up to about 70mph.
Logged
Oyley
CB500X Master
Bike: CB500x 2019
Country:
Reply #17 on:
October 29, 2020, 08:49:27 PM
It's not so much about a person's overall height,its the height from your arse on the seat to the top of the head...
Just the same with seat heights...its ones inseam that matters.
My pal is the same height as me yet his bloody legs are three inches longer ,the sod ! 🥴
Logged
vackor
CB500X Member
Bike: CB500X 19'
Country:
Reply #18 on:
October 30, 2020, 04:30:13 PM
Flashp
I further developed the proper adjustment of the windscreen. I didn’t have enough to move up and down. I sawed it so it could be adjusted in any direction. No turbulence, height 1.86m.
//www.youtube.com/watch?v=UdP2TY2-SK8
Last Edit: October 30, 2020, 04:36:55 PM by vackor
Logged
motorboy
CB500X God
Bike: 2019 CB500X
Country:
Reply #19 on:
October 30, 2020, 05:28:35 PM
Is that something you bought or made yourself
Logged
Pages:
1
2
3
Go Up
Softer more comfortable suspension question
Rally Raid
CBmidlifecrisisX
Today
at 01:48:34 AM
A better seat
Modifications, Accessories, and Appearance
motorboy
Yesterday
at 11:40:52 PM
Tool Kit
Falang
Yesterday
at 11:25:47 PM
2017 w/full Rally Raid kit for sale
Bikes for Sale
RDoedens
Yesterday
at 09:52:49 PM
Painted Red Tubes?
Ruggybuggy
Yesterday
at 08:42:40 PM
Where to start?!
Rally Raid
JMo
Yesterday
at 08:32:41 PM
The X Ancestors
On Two Wheels
Swanny
Yesterday
at 08:21:09 PM
Engine reliability
Spadger2
Yesterday
at 08:12:20 PM
How to Replace LEAKY WATER PUMP!!!
Maintenance and Servicing
LightRider
Yesterday
at 02:21:57 PM
Inexpensive soft luggage
kmsz
Yesterday
at 01:44:15 PM
