Hi all
Yesterday 2 km from my home (after long driving in the rain), the motorcycle shut down during riding, I immediately use the starter and succeed for a few meters, and then it shut down again.
After I took it home by working I looked if the killing switch has an issue because I didn't hear the fuel pump during ignition.
I use WD40 and click on\off and cleaned all the residue and the ignition was good.
Today I had the same issue but no sound of the fuel pump although I played with the switch.
I open the switch and clean everything and lubricate but failed to ignite the fuel pump (during switch on)
I am wondering if someone has familiarity with these issues or have a lead or what other inspection I should do?
I already checked the:
battery voltage Good
Fuse box Good
killing switch cleaned and checked by resistance for cuts\shorts
My main diagnostic is that during switch on the fuel pump doesn't turn on
Thanks
