Author Topic: Guaimi gear indicator, set up  (Read 171 times)
Offline Grizzly
on: January 12, 2021, 03:46:58 PM
Hi all
I recently bought and fitted a Guaimi gear indicator to my 2018 cb500x (xa-h). No problem fitting. I switched on the ignition, gave it a few moments to go though its set up procedure and fired the bike up. I was faced with a letter on the indicator, with the bike on centre stand. I selected 1st with a @2000rpm, let the clutch out and eventually it registered 1. I repeated the process, but ended up with only 5 gears registered. Thinking I had made a mistake I repeated the process with no change. I then disconnected the plug, switched off, pause, re connected and tried again with no success.
The device came with no instructions, but before I return it, has anyone had a similar experience? How did you overcome it? Does the device have a memory which can be erased?
Sorry about 'War and Peace'..... and thank in advance. Paul
