Just a little tip I started using years ago when I did more off-road riding, tiny dab of paint on top of each fork leg matched up with another dab lined up on top yolk, same on bottom yolk and fork legs,makes it quick and easy to do a quick line up after an off. Just slacken front axle, line forks tighten everything up and away you go, if you do this and it’s not right you know somethings bent, I still do this on my bikes,makes it easy when I strip forks to work on. Obviously you need to start with a lined up front end but it saves loads of time.
