Author Topic: OEM Heated grips not working  (Read 540 times)
Offline QiqiRider
  • Country: nl
on: January 21, 2021, 08:34:10 AM
Goodmorning lovely people!
So about four days ago I bought my CB500X and it was already fitted witch OEM heated grips.
But the only problem is, they are not working.
When pressing the button it only starts flashing red and doesn't heat up.
During the whole ride they were flashing, the seller thought it had something to do with the fuses. Checked them all but they all seem to be doing fine.
Searched the whole internet but never found anything or anyone with the same problem. So I have no idea where to start.
Is there someone who has experienced the same with their heated grips, or has any clue as where to start/how to fix it?
Any help is much appreciated!
Re: OEM Heated grips not working
Reply #1 on: January 21, 2021, 08:08:41 PM
It seems like some protection logic or so.
I'd check the connection to the throttle side first.
Online John1411
  • Bike: 2016 in red
Reply #2 on: January 22, 2021, 07:31:52 AM
Googling found these installation instructions, and there's a trouble shooting bit at the end. Though it's not very comprehensive  :003:
https://www.cb500x.com/index.php?action=dlattach;topic=384.0;attach=800
Offline QiqiRider
  • Country: nl
Reply #3 on: January 22, 2021, 02:20:26 PM
Thanks! I also found the installation manual, but it indeed doesn't seem to have very extensive troubleshooting.
Connections all seem to be good. No breaks or anything.
Reply #4 on: January 22, 2021, 04:31:15 PM
Have you checked the resistance of the heating pads? Also have you measured battery voltage?
How did you confirm that connections are good?
Offline UnmzldOx
Reply #5 on: January 22, 2021, 07:56:05 PM
Thinking only:
Two of three leads on left grip should be pos and neg for the heating element. Measure resistance between those two and from each to the bar clamp. Should be 24 ohms, open, open respectively. The right grip has just the two leads and should have same values. The control module might detect a short to the frame, meaning low resistance on the lead to frame measurement.
