Author Topic: Max Weight For OEM Panniers  (Read 449 times)
Offline LoneWallyUK
  • Find me on YouTube - LoneWallyUK
on: February 15, 2021, 08:02:09 PM
So I'm still looking at panniers for my 2013 X. I've comeback to looking at the Honda OEM panniers. I'll be the first to admit that I think the pannier frames are not the sleekest looking but the fact that the panniers don't appear to be wider than the bars is a bonus. One thing however is I can't seem to find and information on weights for each pannier.
2013 Honda CB550X. Find me on YouTube
Offline zoomnad
  • Bike: 2020 CB500Xabs
Re: Max Weight For OEM Panniers
Reply #1 on: February 16, 2021, 09:48:05 AM
8.8 LBS or 3.85 KG per bag.
"You meet the nicest people on a Honda"
Offline LoneWallyUK
Reply #2 on: February 17, 2021, 07:00:33 PM
*Originally Posted by zoomnad [+]
Cheers do you have a picture of the sticker or any documentation?
Offline zoomnad
Reply #3 on: February 17, 2021, 09:17:26 PM
TOOLS AND SUPPLIES REQUIRED
Socket (10 mm)
Ratchet
Open-end wrench (10 mm) Long nose pliers
Isopropyl alcohol
Shop towel
Torque wrench
TORQUE CHART
Tighten all screws, bolts, and nuts to their specified torque values. Refer to the Service Manual for the torque values of the removed parts.
Item N·m kgf·m
6 mm flange bolt and nut 12 1.2 9
MAXIMUM LOADING CAPACITY
• The weight of the cargo must not exceed the following maximum loading capacity:
Maximum Loading Capacity Right pannier 8.8 lb (4.0 kg) Left pannier 8.8 lb (4.0 kg)
INSTALLATION
CAUTION
To prevent burns, allow the engine, exhaust system, radiator, etc., to cool before installing the accessory.
3.
Remove the reflector as shown.
• Repeat on the right side.
      Ibf·ft
REFLECTOR
NUT
   4.
Install the reflector stay as shown.
6 mm FLANGE NUT
1.
2.
<Rear side>
Install the separately sold pannier stay B.
Offline LoneWallyUK
Reply #4 on: February 22, 2021, 04:54:43 PM
Cheers. Just one more thing roughly wants the internal dimensions of pannier? I'm also guessing you ruse the bolts that hold the grab handles on.
Last Edit: February 22, 2021, 04:56:49 PM by LoneWallyUK
Offline zoomnad
Reply #5 on: February 23, 2021, 10:17:58 AM
Each bag is 29L and when buy you the stays, it has the hardware you will need. The fit and finish is very good after all it is Honda and made for the bike. I also looked at Givi and Shad. The Honda bags are the most expensive, then Givi, and the Shad. My Honda bags (panniers) are tight to the bike where the others stick more. And one more thing, up in till Honda changed the ignition key, (not sure when) you can have one key, my 2016 had the same key. My 2020 does not so I have two keys. With Givi and Shad two keys. Hope this helps.
Offline LoneWallyUK
Reply #6 on: February 24, 2021, 06:31:03 PM
Yh I've pretty much looked at everything that has caught my attention. Since I'm not bothered about new/new old stock or second hand with a marks here and there so prices are actually better. The Honda's being the tightest on the bike are selling point to me. I've got a 2013 so I'm know I'm fine.
In cm's do you know the in renal dimensions of the OEM pannier?
