Author Topic: Repaired puncture in rear, now ABS light stays on  (Read 7666 times)
Offline Grim Rider
Re: Repaired puncture in rear, now ABS light stays on
Reply #10 on: February 21, 2015, 09:41:50 AM
ABS light should go out when you get to 6 mph I think.
2017 BMW RnineT Racer S; 2001 BMW R1150 GSA; 1990 BMW K1; 1998 Suzuki DR350S; 1978 Laverda Jarama; 1977 Honda Camino;1962 AJS 250 CSR
www.thegrimrider.com
www.bldr.moonfruit.com
Offline Cam
  • Bike: Black CB500x
Reply #11 on: February 22, 2015, 09:45:55 AM
*Originally Posted by Oxna [+]
Thanks for those replies.
I will need to re-visit the manual but there's two fixings for the calliper, one for the axel to go through and the other a small lug into which a protruded piece of steel on the frame slides so I can't think what I've done wrong.
I am assuming the ABS light shouldn't stay illuminated in yellow after start up? I've run it up to 30 mph on stand but light stays on!
I will re-post upon resolution,
Thanks
As Grim said, need to get up to 6Mph or 10Km/h to activate the ABS system and the light goes out.  Not sure spinning one wheel while on the stand will do it even if you got a wheel spinning at 30Mph?!
Offline Defender
  • Bike: Yamaha YBR
Reply #12 on: February 22, 2015, 10:09:08 AM
Should think both front and rear sensors have to detect 6mph before abs light goes out.
If I can help somebody as I go along, then my living has not been in vain.
Offline Oxna
  • Bike: CB 500 X
Reply #13 on: February 22, 2015, 02:59:11 PM
Thanks again for those replies, I'll need to try the bike on the road when the weather improves and with a bit of luck that should sort it, Cheers
Offline Oxna
  • Bike: CB 500 X
Reply #14 on: February 25, 2015, 03:56:39 PM
ABS light went off as soon as I got BOTH wheels turning rather then the rear only on the stand!  Cleaned out brakes/pistons whilst wheel was off too. Thanks for help with this! Oxna
Offline Defender
  • Bike: Yamaha YBR
Reply #15 on: February 25, 2015, 05:45:18 PM
Result!!! Good man Oxna, glad you're sorted.
Offline Long Ride
  • Don't Let Up
  • Bike: 2019 CB500X ABS
Reply #16 on: September 23, 2020, 03:20:10 AM
Can someone look at this picture and tell me if the spacer is supposed to sit further into the wheel so that the shoulder or flange is tight? Mine looks to be sitting too proud and my ABS light is also staying on after a tire change.
Long Ride
Offline Long Ride
  • Don't Let Up
Reply #17 on: September 26, 2020, 02:01:01 PM
Ok so my spacers were some how swapped at the dealer when I took the wheel in to have them mount the new tire. The flanged washer goes on the sprocket side...thanks to Greg at ADV rider and a parts manual exploded view I was able to fix mine so the ABS light goes off at 6 mph.
Long Ride
