Author Topic: Mini LED Lights  (Read 58557 times)
Re: Mini LED Lights
Reply #200 on: March 31, 2019, 04:31:09 PM
Relay has yet to be done since it's a PITA to change, have to get under the tank . Plus its not here yet. So for now it's hyperflash city .I purchased the relay directly from CUSTOMLED.COM but as you see it's available on Amazon also.
https://www.customled.com/products/elfr-1-h-electronic-led-flasher-relay-4-pin-honda
BTW Credit goes to nbsdave for putting me onto the bulbs and lenses. Thanks Dave !.
Last Edit: March 31, 2019, 04:43:05 PM by CB-500-X
Offline nbsdave
  • Bike: 2018 500X, ABS
Re: Mini LED Lights
Reply #201 on: March 31, 2019, 06:56:12 PM
*Originally Posted by CB-500-X [+]
you are welcome, it's always good to share ideas.
Now, when the flasher gets to you, we will need good pics of where to find it to make the swap.
Re: Mini LED Lights
Reply #202 on: March 31, 2019, 07:06:20 PM
Pics and instructions forthcoming , soon as the relay gets here and I have a little time off to do the job.  :169:
Re: Mini LED Lights
Reply #203 on: June 15, 2019, 02:57:45 AM
Have not had time to fit the relay as of yet however the lights are great going to try and do it this week end, maybe .
Re: Mini LED Lights
Reply #204 on: June 15, 2019, 11:32:57 AM
Lights up bright Orange when turn signals or flashers are activated
Stays on super bright White as running lights ( as bright as the LED driving lights for visibility )
Turn signals on
Turn signals off , turns bright White
I'll have to look into this as it's a good way to 'install' DRLs. In the UK, the indicators aren't required to work as marker lights, so some wiring would be needed.....guess it's a case of comparing wiring diagrams
so just to confirm:
when running, both indicators are white marker lights (with clear lenses fitted)
when the indicator switch is operated, the indicator flashes orange as per
indicator switched off, returns to white marker light?
Re: Mini LED Lights
Reply #205 on: June 15, 2019, 11:38:20 AM
“when running, both indicators are white marker lights (with clear lenses fitted)
indicator switched off, returns to white marker light”
Exactly !
Re: Mini LED Lights
Reply #206 on: June 15, 2019, 03:40:34 PM
Exactly !
thanks....
Re: Mini LED Lights
Reply #207 on: June 15, 2019, 11:17:41 PM
Finally had a little time to install the relay. Works great !  :152:
Take to side covers and the upper tank trim off. Take the two front tank bolts out. Loosen the single rear tank bolt/nut ( do not remove ) Pivot the tank up ( no more that 3-4 inches ) Prop the tank up. Pry out the relay with a long flat head screw driver ( gently) Connect the new relay to the connector and push it back into the hole. Secure the tank. Put all the trim back on and you're done !  :046:
Re: Mini LED Lights
Reply #208 on: June 15, 2019, 11:21:23 PM
Re: Mini LED Lights
Reply #209 on: June 16, 2019, 11:41:05 AM
Great pics and clear information....Thanks for sharing. :028:
Think I'll be investigating the UK/EU wiring in due course. If I do the conversion, I'll add it on to your post....just strikes me as a decent way to improve conspicuity without having to shell out too much for additional lighting and somewhere to mount it....
