Author Topic: Water pump repair  (Read 4393 times)
Re: Water pump repair
Reply #30 on: April 19, 2020, 07:17:28 PM
*Originally Posted by vackor [+]
Hi! What leaked to you, water or oil? I have this problem too. 6 months, 1800 km, and is leaking oil.
It was coolant. Did you checked that the oil doesn't come from chain?
Offline vackor
Reply #31 on: April 20, 2020, 05:19:54 AM
Of course, from the little hole. I have no luck. In 2003, I bought a new Aprilia Pegaso 650ie. By the age of 1, the oil started to leak even more there. I did not want to go in for repair under warranty (it did not want to wait half a day). I replaced it with what I bought at the bearing store. He endured 15 years, he had no more problems with it. The Pegaso also has a 12x26x7 oil seal, but there are both sides. I just called the service, they just haven't called me back yet. Maybe this is that the shaft is not straight? It is leaking more and more.
*Originally Posted by timur [+]
Reply #32 on: April 20, 2020, 04:31:43 PM
Leaky water pumps on CB500X and Mayan dissapearance are one of the biggest mysteries of this time. And as I can see Honda decided to continue with the same flawed design - don't understand why the didn't resolved the issue since 2013  :157:
In my case since water pump replacement on my bike it is all right - made 17000km and no leaks anymore. However I check coolant level almost everyday - just in case.
Last Edit: April 20, 2020, 04:35:06 PM by timur
Offline bones
Reply #33 on: May 23, 2020, 09:15:03 AM
  thank you Timur.
  of great help. brill pictures as well.
   BONES. :047:
