Author Topic: Question re Madstad Windshield for those that have them  (Read 1535 times)
Offline terryfred
on: September 12, 2019, 07:57:35 PM
I'm looking a windshields for my new 2017 CBX.  It seems many of you have a Madstad windshield. I've found through J & P Cycles that they have this item for our bikes.  I'm looking at the 20" clear windshield for $270.  It comes with "adjustable brackets."  For those that have this, did the Madstad fit without modification onto the CB500X brackets?  Any issues and recommendations you might have?
Terry
Online oldtexan
  • Bike: 2018 CB500x ABS
Re: Question re Madstad Windshield for those that have them
Reply #1 on: September 12, 2019, 09:39:44 PM
The Madstad brackets fit perfectly.  The adjustable brackets mentioned allow the windshield to easily raised or lowered, as well as the adjustment of the angle of the windshield (angle from vertical).  I recommend the purchase of the winglets; they help quite a bit in blocking airflow over your torso.
I and others have noticed that the well nuts used for the install eventually will have to be replaced as they tend to get cut by the natural movement of the windshield.  This is not a big problem to correct.
Offline zoomnad
  • Bike: 2020 CB500Xabs
Reply #2 on: September 13, 2019, 12:05:18 PM
I bought the Puig touring windshield with the Visor. I'm 5'6" and it is perfect on the lower part of the windshield mount. $170 from Revzilla.
"You meet the nicest people on a Honda"
Offline bitdist
Reply #3 on: September 14, 2019, 07:54:44 AM
I had no problem fitting mine at all and it got rid of the buffeting for me.  I got the 20"
Offline Hobber
Reply #4 on: September 17, 2019, 03:31:49 PM
PUIG Windshield
Since I (1,86 m tall) was unhappy with the Buffeting along with the Honda Windshield I have made several Trials. By the way the space between the Fuel Tank and the raiser of the handle bar got closed by a 2,5mm rubber piece as per attached photo.
Comparison Original Honda Windshield vs Aftermarket Shield from Puig.
Color: Smoke Grey
Height difference: 95 mm
Height difference Low Pos. Honda Shield vs. Puig Max approx. 135mm
I tried to move the Honda Shield 80 mm up with plate extension w. 40 mm hole spacing. The Gap got closed by cardboard blades for trail purpose. It worked but the gap between upper Frt Fairing edge and Shield edge and the small Shield at that height looked ugly.
This drove me to the decision to buy a Puig Shield at cost of 89 which came w. a fuel coupon of 10 (so 79 was OK to me).
I moved the Puig Shield to the upper position +40 mm as per hole spacing at the Honda Shield bracket.
The Gap (bad looking and allowing air stream) between upper Frt Fairing edge and Shield edge got closed by Aluminum Deflector Plate cutted from 2 mm Aluminum Sheet metal, bended and dull black painted.
For me the combined solution works perfect and it does not look that bad. May be an idea for other CB500X 2019 drivers.
Last Edit: September 17, 2019, 03:36:07 PM by Hobber
Offline Hobber
Reply #5 on: September 17, 2019, 05:33:05 PM
Here some more pics
Offline BenjaminCB
  • Bike: PC64
Reply #6 on: May 20, 2020, 05:45:34 PM
*Originally Posted by Hobber [+]
PUIG Windshield
 :481: Hi mate, I also have a puig screen on my 2019. Funnily enough i have ended up doing the exact same things as you. I too made some side deflectors to sit in that gap between fairing and screen. I also made a little fork tube deflector. It's great up to about 90kph, a nice quite bubble. However, at highway speeds it's still a buffeting disaster. Do you also experience this problem or is this setup perfectly quit for you?
Offline CaptCapsize
  • Bike: WR450 DL650 500X
Reply #7 on: July 16, 2020, 05:56:27 AM
I finally put a Mastad windshield on me 2015 CB500X. I previously had a 2016 windshield which was an improvement of the original.  The Mastad and bracket I installed were for a Africa Twin.  I picked up at a rally swap meet last summer.  I just got around to fabricating an adapter and it fits pretty well.   I still need to either cut the shield a little or move the bars back (rox Riser) because it interferes with full stop turning.
The good news the windshield really improved the riding. With it top mounted and about half way extended in it track the airflow was just above my helmet.  I am tall and the CB felt too short for comfort, so I added a Seat Concepts Tall Rally Seat.  It adds 1.75 inches to the seat height.  That unfortunately it put my head that much higher.  The new (used) windscreen make is the airflow much less turbulent and at 80mph the wind is an inch above my helmet.
Also I think the Africa Twin windshield look pretty good on my Halfrica Twin.
"Everyone must believe in something.  I believe I'll have another beer" W.C. Fields
Offline ncroadtoad
Reply #8 on: July 16, 2020, 12:21:47 PM
what oldtexan said +1
Just damn happy to be here...
Offline wardie
  • Bike: 2016 CB 500 X
Reply #9 on: July 16, 2020, 01:01:38 PM
Hobber why does your wheel look off center?
Wardie
