Author Topic: 12v socket  (Read 1413 times)
Offline racer
Re: 12v socket
Reply #10 on: April 18, 2020, 05:44:10 PM
Yepper.  But check your owner manual or look under the seat to see how big the fuse is.  I just use mine to power my GPS.  I wouldn't run and heated gear off it.  I installed a battery tender pig tail that is fused direct from the battery, that I use for my heated vest and air pump.  Good luck,  Racer
Offline gonzalo.a.d
Re: 12v socket
Reply #11 on: April 19, 2020, 01:04:20 AM
I have a similar USB installed in my 2019 cb500x, it is connected to the auxiliary socket prepared for this purpose, it works well and it disconnects when I remove the key from the motorcycle.
It fit well into the hole prepared for the original Honda 12v socket.
Offline dark011
Re: 12v socket
Reply #12 on: May 20, 2020, 05:30:37 PM
Could this same OP in the front be used to power LED lights AND a USB charger?
Online Oyley
Re: 12v socket
Reply #13 on: May 20, 2020, 06:02:41 PM
It does say on the Honda socket...max 3 amp
Online Ruggybuggy
Re: 12v socket
Reply #14 on: May 20, 2020, 06:45:42 PM
I just installed one off Amazon.  Works great and no adapter needed to power my phone.
Offline dark011
Re: 12v socket
Reply #15 on: May 22, 2020, 07:15:06 PM
Thanks, I haven't picked up my bike yet  :002:.  It loos like it is indeed meant for small accessories, like a 2.1A USB charger, although it could run two of these (drawing 0.68A each):
https://www.superbrightleds.com/moreinfo/led-light-pods/led-light-pod-2-modular-led-off-road-work-light-10w-900-lumens/1699/#tab/specifications
but not everything at the same time.
