Motorboy, the bikes original Dunlop rear tyre lasted me 25k miles and the replacement, a Bridgestone T31 which I have just replaced 3 weeks ago had 35k miles on it. The bike is currently at 61k miles.
(Of course the tyre was completely squared off and at the wear limit when I finally replaced it).
The front original Dunlop lasted 10k miles, replaced it with a Bridgestone BT23 which lasted another 30k miles and the current front is a T31 with 20k miles with little to no signs of wear at all.
Running pressure for me all year round are :
Front =36PSI
Rear = 40PSI
Those are superb mileages.
Your front tyre pressure is quite high,Honda recommend 29psi.After experimenting with my tyre pressures over the last 3000miles since I bought the bike,I've settled on 26front and 36rear.I only ride solo and weigh 90kg with a 4kg tank bag on board and no other luggage.
The bike on original Dunlops feels planted wet or dry at those TPs,though I'm a cautious rider in the wet.
I can't see me getting anywhere near your mileages for the rear tyre as the centre section has already shed 2mm of tread(6mm new,now 4mm).I'd estimate 6000miles max for my rear before it needs changing.
