Author Topic: Horn Relocation 2019 CBX  (Read 1293 times)
Re: Horn Relocation 2019 CBX
Reply #10 on: February 09, 2020, 11:46:10 PM
*Originally Posted by adman [+]
I would like to install an Italian 2-tone horn. (Italians build the best horns)  :005: I have a question: is the standard horn of the CBX 2019 already controlled by a relay that I can use for it? Unfortunately I have no circuit diagram here. Can anyone help me further?
Thank you.
No you’re going to have to beef it up. The Denali sound bomb sounds exactly like an Italian air horn ( I used to have fiaam air horns on a car) It comes with a complete harness and relay. All you have to do is connect it the battery and one wire to the existing wire that goes to horn. Much easier and safer.
Offline adman
Reply #11 on: February 10, 2020, 03:16:51 PM
Thank you for the information. Then the standard horn is probably connected directly because it does not require as much power. I will then buy a double horn with relay and build the appropriate cable set myself.
In Germany, however, we are not allowed to use all horns, they must have an E number.
Offline woody
Reply #12 on: February 11, 2020, 07:01:19 PM
Thanks for this, did similar with my 2018 today, the standard horn is somewhat just OK but looks dam fugly. Think I'll go for denali in the future, just soooo much stuff on my shopping list to get before :821:
