Author Topic: To anyone with water pump problems  (Read 1459 times)
Offline spirit986
  • Bike: 2019 CB500X ABS
  • Country: mk
Re: To anyone with water pump problems
Reply #10 on: August 02, 2020, 10:15:43 AM
There is are several threads here where several guys have had lots of problems with water pump seals.  I believe they had bikes in the '13-'15 model range.  It was a manufacturing problem with the water pumps...  Do a search for water pump leaks.
A few days ago I noticed that the coolant level on my new 2019 model is very much bellow the minimum. It was barely visible in fact, the blue liquid was just barely peaking out from the coolant hose. I added a bit of distilled water to compensate for this and I plan to report this issue to Honda service once I bring in my bike for the regular servicing this month.
Last Edit: August 02, 2020, 10:18:06 AM by spirit986
Reply #11 on: August 02, 2020, 03:33:15 PM
That was discussed before you can file it under they all come low
Offline spirit986
  • Country: mk
Reply #12 on: August 02, 2020, 03:52:14 PM
Discussed before where?
Reply #13 on: August 02, 2020, 03:59:26 PM
Right here on this forum-- do a search
Offline japes1275
Reply #14 on: August 02, 2020, 08:25:10 PM
I think I was part of the discussion - mine lost a bit after the first few hundred miles. I topped it up when I did the first service.
Online Neox
  • Bike: 2016 cb500x
Reply #15 on: August 02, 2020, 08:30:38 PM
*Originally Posted by spirit986 [+]
Here:
https://www.cb500x.com/index.php/topic,9744.0.html
Offline BenjaminCB
  • Bike: PC64
  • Country: be
Reply #16 on: August 02, 2020, 08:35:49 PM
Not only the 13-15's. My 19 has decided to join the leak party...
https://www.cb500x.com/index.php/topic,10018.msg100297.html#msg100297
Offline spirit986
  • Country: mk
Reply #17 on: August 02, 2020, 08:39:14 PM
Thank you  :046:, I was searching with the keyword pump, which is why I was failing  :084:
Last Edit: August 02, 2020, 08:55:59 PM by spirit986
