Author Topic: GSX-R 750 shock reservoir clearance.  (Read 842 times)
on: February 21, 2020, 01:39:18 AM
No cutting needed. Shock clears the plastic that covers the wire/s. It’s a tight , but it fits without cutting. Here’s the pics.
Re: GSX-R 750 shock reservoir clearance.
Reply #1 on: February 23, 2020, 06:32:26 AM
Original shock clearance
Online Ruggybuggy
Reply #2 on: April 25, 2020, 01:15:22 PM
Interesting.  Is the shock length contracted and extended the same?  Hiw do the spring rates compare?
Online denislordm
  • Bike: CB500x
Reply #3 on: April 25, 2020, 01:22:41 PM
Can I just ask WHY?
What sort of riding do you do ? road or off road?
What expectation did you have and is it worth it?
cheers buddy
 :002:
Reply #4 on: April 25, 2020, 07:51:10 PM
The Gsxr shock is a _MUCH_ better one. It has real good and consistent damping, four way adjustable (slow and fast compression, rebound and spring preload), and add a about 10mm more height and travel compared to stock.
Only negative is that because of the reservoir setup of the shock, it only fits non-ABS bikes.
Reply #5 on: April 26, 2020, 09:32:48 AM
Yeah what he said.  :460:
Online denislordm
  • Bike: CB500x
Reply #6 on: April 26, 2020, 01:32:37 PM
OK Guys thanks for that - so now I know   :001:
Online Ruggybuggy
Reply #7 on: April 26, 2020, 02:02:22 PM
It's too bad that we can't find a replacement for the CB rear shock from another bike for the 2019 and 20.  On my previous NC750X I was running a Aprilia rear shock with a custom spring and it worked very well.
Reply #8 on: April 26, 2020, 03:03:58 PM
Guys please this post it to show people the clearance for the gsxr shock install. There are several other alternative shock post. Please stick to the subject.
“ Shock clearance for GSX-R shock”
Use the search button for replacement shocks.
Last Edit: April 26, 2020, 03:12:09 PM by CB-500-X
