Author Topic: 1st start : Ignition key lock dead  (Read 1021 times)
Offline McLeod
  • Bike: CB500X 2016
  • Country: fr
on: March 13, 2020, 01:00:38 PM
I won't give you the details, but I had a lot of trouble getting my first bike. But my last problem is on the top.  :191: :013:
I had just received the keys to my CB500x (2016 model 2017 - 20000km). I go on board and tell myself that I haven't tested the lock of the ignition key (Neiman in French, I don't know the word in english). And so... the lock is PERFECT ! Very Perfect ! Impossible to steal the bike, but ... impossible to unlock or remove the key ! :125: The garage where I bought the CB500x didn't find a solution, and Honda told them they knew about this problem on CB500. :033:
Now, I'm waiting since 2 weeks a new ignition key lock assembly, which is out in stock Europe. Today, the Kit is finaly arrived at Honda Europe in... the Netherlands. It still take 48/72 hours to arrive in France and an another 48 hours to fixe my bike. So with chance (yes, just a little please), I should be able to drive my CB500x for the 1st time in the middle or at the end of the next week. :164: Great start !
Have you heard somethings about this problem?
Last Edit: March 13, 2020, 01:06:39 PM by McLeod
Re: 1st start : Ignition key lock dead
Reply #1 on: March 13, 2020, 03:56:09 PM
That must be SOOOO frustrating!  Not a problem I've seen on here, but someone may say different soon.....  :023:
Offline McLeod
  • Bike: CB500X 2016
  • Country: fr
Reply #2 on: March 13, 2020, 03:59:34 PM
I searched on the web without find same problem.
Online Neox
  • Bike: 2016 cb500x
  • Country: fr
Reply #3 on: March 13, 2020, 07:05:04 PM
Sorry, i write in french, more simple for me...
C'est un problème de barillet. Tu as du pousser sur la clé et tourner vers la gauche, après le barillet remonte et on peut sortir la clé. Donc soit le barillet n'a pas assez ou trop tourné, soit il ne remonte plus car un défaut l'en empêche. Les pistons de la serrure étant toujours en contrainte ils bloquent la clé.
Testé un coup de dégrippant puis manipulation?
Online VA-CB500X
Reply #4 on: March 13, 2020, 07:12:35 PM
*Originally Posted by Neox [+]
I would definitely try a shot of penetrating oil (dégrippant).  Then let it sit for a bit.  The oil might free it up.  Keep working at it.
Online Swanny
  • Bike: 20 500X & CB1300
Reply #5 on: March 13, 2020, 08:10:24 PM
+1
Offline Lancs-lad
Reply #6 on: March 13, 2020, 09:02:00 PM
On ignition barrels or any lock with pins you should use a dusting of Graphite Powder as any oil based product will only encourage debris to stick in the lock.
Red Rose Classic MCC
Online VA-CB500X
Reply #7 on: March 13, 2020, 09:40:51 PM
Normally, yes.  But he already has debris in the lock -- his KEY has been stuck in it for almost two weeks.  I think under the circumstances that penetrating oil has a much better chance of success than graphite powder.  It will be very difficult to get that powder in the lock tumbler with the key already in it.
Offline McLeod
  • Bike: CB500X 2016
  • Country: fr
Reply #8 on: March 14, 2020, 10:14:10 AM
I didn't leave very quickly with the bike after the purchase. :015:  When they saw me at war with my keys.  The mechanics came to show me how to do it. LoL :008:
They tested several cleaners, penetrating oil and a graphite spray. Nothing worked, the system didn't move a millimeter.
Tell me, my CB500x will sleep outside.  You advise me to cover some point of bike?  I don't usually cover my scooter, the humidity gets under the cover in daily use.  I only do this when I stop driving for several days. Maybe we can 3D print a cover for ignition barrel.
Online Swanny
Reply #9 on: March 14, 2020, 10:20:44 AM
I'd cover it and take out the fuses and spark plug
