Author Topic: 13-18 CB500X: Changing OEM chain tension screws to 13mm Nyloc...  (Read 2173 times)
Seems every one is bored with the stay at home order if this is the best conversation we can come up with--I see nothing wrong with the Honda set up if you want to use nylock nuts use them but I see no advantage
Offline Ceddy17
  • Ed
  • Country: be
It was Brit humour...some here will get it instantly, honestly.
I know...I was merely making conversation...No worries..
Ed.
... don't concentrate on the finger ...  Stay Safe  ...
Offline bones33
Re: 13-18 CB500X: Changing OEM chain tension screws to 13mm Nyloc...
Reply #22 on: September 24, 2020, 05:30:26 PM
Just drill through the end of the screw, not the nut and install a small pin or better yet, safety wire. This way the 12mm can't fall off.
Oh yeah. Yes, my Husqvarna breaks because it has 13mm's on it.
Offline Superplasma
Reply #23 on: October 24, 2020, 11:24:22 AM
+1,
Superplasma.
