Author Topic: Wiring Diagram and Instructions?  (Read 9039 times)
Offline Ruggybuggy
Re: Wiring Diagram and Instructions?
Reply #100 on: November 28, 2020, 02:27:38 PM
*Originally Posted by Russ [+]
OK, I've got the lights on order from aliexpress - getting the ones with a relay included -
https://www.aliexpress.com/item/4001012115493.html?spm=a2g0s.12269583.0.0.39494c050g9vAP
This is the wiring diagram for these lights -
And this plug from ebay -
https://www.ebay.co.uk/itm/Honda-CB500X-F-R-Auxiliary-Output-Options-Plug-1-x-3-way-Connector-Set/282968622281
I intend to connect the power supply to one of the ignition live plugs (either under left fairing, or under the seat).
I want these lights to come on when I turn on my main beam.
Am I right in thinking that I will only need to connect the Green wire from the 3 pin plug to terminal 86 on the relay ??
Or do the Blue & Purple wires need connecting anywhere ?
I guess I can do away with the supplied switch & just join the 2 switch wires together if I want to leave the switch off ?
I've wired mine so that my led driving only come on when the high beam are on.  When the lights are on low beam it is not possible to have the led driving lights on.  I did it this way so when I drive at night I my ding light will turn off automatically.  During the day i always ride with my high beams on to be seen by other motorist.
Using the wiring harness you have I connected the red power wire (positive) to the violet wire under the right cowl.  The negative wire on the harness goes to the violet wire.  The control switch wiring has two wires.  These wires are used to operate the control box to turn the led driving light on.  It's basically a relay.  One of the wires will go to the blue wire on the Honda connector.  The other wire will go to the ground wire on the Honda connector (green wire).  The colour of the wires on the control harness will indicate which is the positive and which is a negative wire.  The black will be negative and will connect to green wire on the Honda connector.  The remaining wire will go to the blue wire on the Honda connector.   The only reason that it matters which way they go is because some relays use a suppression diode.
Hopefully all that is clear.   :087:
Offline Russ
  • Bike: Honda CB500X
Reply #101 on: November 28, 2020, 03:33:18 PM
*Originally Posted by Ruggybuggy [+]
Thanks for your reply, that is how I want to connect mine, as my daily commute is along dark unlit narrow lanes.
Can you check your post please - you have mentioned the violet wire twice, & is this connection into the 3 pin plug under right cowl.
"I connected the red power wire (positive) to the violet wire under the right cowl.  The negative wire on the harness goes to the violet wire."
Think I have this bit right now - I have to do away with the switch, one of these wires will go to the blue wire & the other wire to the green wire in the 3 pin plug.
I do not get the power supply from either the battery or one of the aux plugs, only the 3 pin plug is used for all connections ?
Getting there slowly lol, thanks for all your help. Just want to be 100% sure I get it right first time when I get delivery and can fit it.
Offline Ruggybuggy
Reply #102 on: November 28, 2020, 03:49:02 PM
Sorry, the negative wire on the harness goes to the green Honda wire.  I can't correct my post.
As for the switch your right in that you have to remove it.  The blue Honda wire is positive when the high beam is selected and can be used to operate the control box which is just a relay.  The other wire will be the grounded and  it can be connected to the green Honda wire.
Last Edit: November 28, 2020, 03:59:28 PM by Ruggybuggy
Offline Russ
Reply #103 on: November 28, 2020, 04:54:19 PM
Great, thanks again for your help, all ready to fit now once it arrives :)
Live feed to Purple wire in the plug
Negative feed + one of the switch wires to Green wire in the plug
Other switch wire to the Blue wire in the plug
I guess it is trial and error to see which one from the switch goes to the Blue wire unless one is black & the other a different colour :) ?
Sounds a bit easier than I anticipated now with your help :) :)
Offline Ruggybuggy
Reply #104 on: November 28, 2020, 07:43:28 PM
I think you've got it!
There will probably be different colour wires on the switch harness.  To muddy up the waters just a bit more, because there are only two wires to the switch one of the two must be positive on the driving light harness.  To complete the circuit in the relay power must go to the switch then to ground to operate the relay.  The coil part in the diagram.  Think of the relay as two complete circuits.  One to power the driving lights and the other powers the relay coil to operate the relay switch.
Your probably going to have wire the Honda blue wire (high beam driving light control) to operate the relay coil.  Honda blue wire on one side of the relay coil and the other wide to ground (Honda green wire).  Basically your rewiring the relay control side.  The harness your getting will probably have shrink wrap that will cover up the control box terminals.  You will have to remove the shrink wrap to expose the terminals to see how the relay side is wired.
Last Edit: November 28, 2020, 07:50:33 PM by Ruggybuggy
