Author Topic: side stand  (Read 1216 times)
Offline DorMinoR
  • Bike: cb500x 2018
  • Country: gr
side stand
on: April 30, 2020, 04:13:21 PM
Hey guys how are you? let me get quickly to the matter!
have you ever tried to start your bike while the side stand is lowered? my bike doesn't start other's do start!
what is your bike doing?
cb500x 2018
Re: side stand
Reply #1 on: April 30, 2020, 04:50:54 PM
Starts with side stand down if in neutral, not if it's in gear - check the side stand safety switch?
Offline DorMinoR
  • Bike: cb500x 2018
  • Country: gr
Re: side stand
Reply #2 on: April 30, 2020, 04:58:38 PM
forgot to mention while on neutral does not start and of course while on whatever gear also does not start! it is not of a serious problem for me because either way i didn't crank the bike up while on side stand never! just asking because a friend of mine ones came with the same bike and told me that! the safety switch does work as it should ( checked it )
cb500x 2018
Offline Lancs-lad
Re: side stand
Reply #3 on: April 30, 2020, 09:38:49 PM
Mine starts on the side stand in neutral.
Red Rose Classic MCC
Offline DorMinoR
  • Bike: cb500x 2018
  • Country: gr
Re: side stand
Reply #4 on: April 30, 2020, 09:52:48 PM
ok got it...everyone will tell me the same thing! i don't mind it actually since my bike works fine 2 years now...i don't turn on my bike while on side stant (have centre stand fitted)...much appreciate all of you who answered to my problem!
Last Edit: April 30, 2020, 09:53:21 PM by DorMinoR
cb500x 2018
Offline Ruggybuggy
Re: side stand
Reply #5 on: April 30, 2020, 09:53:40 PM
Mine also starts on the side stand when in neutral.
So what happens when your bike is still running and you extend your sidestand while in neutral?
Offline DorMinoR
  • Bike: cb500x 2018
  • Country: gr
Re: side stand
Reply #6 on: April 30, 2020, 09:56:51 PM
*Originally Posted by Ruggybuggy [+]
if still running and extend it nothing happens...if i step to first gear, with extended stand, it stops immediately
cb500x 2018
Online VA-CB500X
Re: side stand
Reply #7 on: April 30, 2020, 11:05:47 PM
*Originally Posted by DorMinoR [+]
So, your sidestand safety switch is operating normally when the engine is running, but malfunctions when the engine is turned off.
That is very puzzling.
Are you 100% certain that you are in neutral when you try to start the engine with the sidestand down?
Offline DorMinoR
  • Bike: cb500x 2018
  • Country: gr
Re: side stand
Reply #8 on: April 30, 2020, 11:08:03 PM
green N light on
cb500x 2018
Offline DorMinoR
  • Bike: cb500x 2018
  • Country: gr
Re: side stand
Reply #9 on: May 01, 2020, 05:16:33 PM
problem solved guys...while extended side stand and neutral,my bike needs clutch lever pressed to start! maybe it is factory built like this...maybe i hadn't had a problem at all!
cb500x 2018
