Author Topic: How to change (unmount/mount) wheels on your CB500X  (Read 880 times)
Offline trollbiker
  • Country: no
This is how I change my wheels on my 2019 model. I have two sets of wheels, the OEM and the spoked ones from Rally Raid. But the videos covers any wheel change (unmount/mount) front and rear:
4 wheels moves the body, 2 wheels moves the soul.
Re: How to change (unmount/mount) wheels on your CB500X
Reply #1 on: May 09, 2020, 11:32:38 PM
 :762: :763:
Online crispenator
  • Bike: 2015 cb500x
Reply #2 on: May 10, 2020, 01:08:48 AM
 :047: how does the bike goon the hydrolic stand is it secure or do you use some straps
Online DHCBX
  • Bike: CB500X 20MY
Reply #3 on: May 10, 2020, 09:07:55 PM
*Originally Posted by ewryly [+]
:762: :763:
+1  :763:
Offline Ppimouss
  • Country: fr
Reply #4 on: May 11, 2020, 08:37:38 PM
I didnít  need to touch the adjusting screws to remove the chain.
Make sure the shaft is pushed against them when you tighten the nut ( I like to put a wrench between the chain and the sprocket, then turn to put tension on the chain).
Last comment: donít trust the adjustment marks, check for alignment of the wheel.
It wasnít too bad on the CB, though.
Offline Twempie
Reply #5 on: May 17, 2020, 04:30:53 AM
Nice job. And a great job on keeping the viewer engaged, which is not an easy task in the current era of 15 second videos.
Offline Asterix
Reply #6 on: May 31, 2020, 09:46:38 PM
Rear wheel removed today Iíd have been lost without your video. I hope that it will go back on as easily as it came off.
Diolch/Thanks  :152:
Asterix
Offline Asterix
Reply #7 on: June 03, 2020, 08:39:34 PM
Ok rear wheel easy enough, but the front axle will not budge. Iíve loosened/removed all the bolts and it looks so easy in the film to remove it from the left side. This is the first time that the wheel is coming off is this normal? Do I need a special tool or something?
Any advice would be appreciated.
Asterix
Online johnthebigadv
Reply #8 on: June 03, 2020, 09:54:06 PM
*Originally Posted by Asterix [+]
This video should help it is the same as a 500X  just make sure when you remove the brake caliper to support it with some string or wire.
Last Edit: June 03, 2020, 09:58:01 PM by johnthebigadv
Offline Asterix
Reply #9 on: June 03, 2020, 10:23:15 PM
Nice one thank you, 17mm hex bolt is my next purchase. :763: :763:
Asterix
