Author Topic: Broken footpeg - anyone else?  (Read 3074 times)
Offline Oldsolum
on: May 24, 2020, 01:35:00 AM
My right footpeg broke today while taking the bike off the centerstand. I often stand on the pegs with the bike on the centerstand and then rock forward and ride away. When I did that after leaving the gas pump, the right footpeg sheared off. It's something that I've done a hundred times before, and I only weigh 150 pounds, so I guess it's stress fatigue? Has this happened to any of you?
Offline UnmzldOx
Re: Broken footpeg - anyone else?
Reply #1 on: May 24, 2020, 01:48:31 AM
No. Yikes. Were you landing a jump?
Last Edit: May 24, 2020, 01:49:49 AM by UnmzldOx
Offline UnmzldOx
Reply #2 on: May 24, 2020, 03:39:40 AM
Ok. Read your caption now. I've wondered if I should replace mine because they are skewed due to pin and peg hole wear. Did you lose control of the bike for a bit? This kind of failure would happen at the worst moment; up on pegs to manage a rough patch, crossing RR tracks, etc.
Offline Oldsolum
Reply #3 on: May 24, 2020, 04:42:45 AM
No loss of control, because I was in 1st gear and on level pavement. I didn't know exactly what happened for a bit, and I kept paddling my right foot in an attempt to find the footpeg that wasn't there. Fortunately, I was only one mile from home and could just rest my foot on the exhaust shroud until i got home.
Online Ruggybuggy
Reply #4 on: May 24, 2020, 04:46:31 AM
I want to see some pictures of that broken foot peg.
Online Ruggybuggy
Reply #5 on: May 24, 2020, 04:48:23 AM
Sorry I see it now, slow connection.
Online Ruggybuggy
Reply #6 on: May 24, 2020, 04:53:01 AM
Had the bike been dropped or has the foot peg struck something.  Maybe a stress fracture from a previous incident.   :187:
Online Oyley
Reply #7 on: May 24, 2020, 09:50:51 AM
Either my eyes are failing me or you have another bracket there to what I have.
Have you an intermediate bracket in there to lower your standard foot peg position?
One that uses a bolt through the standard foot peg ? As opposed to a pivot bolt and a split pin ?
Online CBRDEAN0
Reply #8 on: May 24, 2020, 10:31:53 AM
Have you drilled the hole bigger in the footpeg to fit those peg lowering brackets ?
Reply #9 on: May 24, 2020, 10:33:04 AM
There is something strange on this picture - you footpeg is attached with threaded bolt instead of OEM pin? I'm sure this is the reason of footpeg breakage - footpeg hole is supported by threaded part of the bolt. The thread fillets acts as crack initiators - they leave marks on soft aluminium and lead to stress concentrations in a hole.
I mean - you can use threaded bolts for this purpose but the threaded part mustn't contact with holes in footpeg and mountings. If the same bolt is used on other footpeg I would suggest you to replace it too preventively - probably it has cracks.
And once replaced both footpegs use bolts that has enough non threaded section - thread should never be in contact with the hole.
Regards
