Author Topic: Lower and wider foot pegs  (Read 2016 times)
Offline DandyDoug
  • Bike: 2020 CB500X
Re: Lower and wider foot pegs
Reply #20 on: June 27, 2020, 02:30:58 AM
2001--2017 GL1800 .
Found the info from a rider on the ADV Forum under the heading" Adventure Bikes not made by BMW or KTM"
Then under the heading "Japanese polycylindered adventure bikes."
Faster,faster,faster , until the thrill of speed overcomes the fear of death.
Offline Ruggybuggy
Reply #21 on: June 27, 2020, 05:58:36 AM
I wonder if something like these for the ST1300 would work?
Offline DandyDoug
  • Bike: 2020 CB500X
Reply #22 on: June 27, 2020, 12:28:30 PM
Maybe, they look slightly different in the shape at the top where the clevis pin goes through the hole .
If I had a pair or at lest access to a pair I would certainly try them.
Please let us know if you do and how they work.
Offline Ruggybuggy
Reply #23 on: June 27, 2020, 02:09:18 PM
I found another listing for the same foot peg and they do list it for the GL1800.  I have the modified BMW foot pegs on now but they are higher up than the stock ones and required quite a bit of shifter and brake adjustment.  They are only $50 so I might try them.
Reply #24 on: June 27, 2020, 03:19:25 PM
Take a look at the stock front pegs that come on the Honda 500 Rebel-if I didn't buy the toppers I have now I would have bought the Rebel pegs-you wouldn't think they would come on a cruiser
Offline Ruggybuggy
Reply #25 on: July 10, 2020, 06:27:34 PM
So I ordered and fitted the pegs yesterday and they work well.  You can index them to the position you want but I suggest some epoxy to make sure they don't rotate.  I like them because they give plenty of room between the peg and levers.  They are also 1" lower than the BMW ones I had mounted before.  I did have to grind a little for a good fit.
Offline DandyDoug
  • Bike: 2020 CB500X
Reply #26 on: July 10, 2020, 09:35:02 PM
They look like they were made for the bike.
I have mine assembled , just too hot in the garage right now to do any fiddling .
Offline Ruggybuggy
Reply #27 on: July 10, 2020, 11:08:48 PM
*Originally Posted by DandyDoug [+]
You bought the same ones?
Offline DandyDoug
  • Bike: 2020 CB500X
Reply #28 on: July 11, 2020, 12:37:02 AM
No I don't think so.
 I ordered mine through my local Honda dealer , item by item from the parts fische
Looked at all the packages as I opened them , everything marked as made in Japan. Kind of surprised me.
I noticed his have an adjustment fastener at the very end of the foot peg. Mine do not have that.
Last Edit: July 11, 2020, 12:38:51 AM by DandyDoug
Offline DandyDoug
  • Bike: 2020 CB500X
Reply #29 on: August 06, 2020, 01:40:08 AM
I have the Goldwing foot pegs mounted and have been on a few rides .
They are way more comfortable than the stock pegs.
I did not feel it required and rear brake pedal adjustments.
On the shift side it's a bit of a problem.
 As others have stated the shift lever is a crap shoot getting it adjusted to the right height.
I wear a size 9.5 USA, or 43 in Europe and getting the shift lever set is presenting a problem.
The problem stems from some limitation of ankle movement all residual from a stroke.
I am close to ok , but still miss some up shifts . Meaning a false neutral at a very bad time.
If I cannot get this resolved the machine will be up for sale.
I do not want an accident causing me to  spend more sheet time.  :110:
