Author Topic: Fuel gauge problem.  (Read 1432 times)
Offline DirttoStreet
  • Bike: 2017 CB 500x
Fuel gauge problem.
on: June 23, 2020, 02:02:42 AM
The other day while riding, my fuel gauge started flashing. All of the bars. The tank was almost full. All other functions seem to be working. I have ran another tank through it since and no change. Any ideas????
Offline UnmzldOx
Re: Fuel gauge problem.
Reply #2 on: June 23, 2020, 11:54:30 AM
yes this helps a lot. Thankyou. I will dig into it tonight
Reply #3 on: June 26, 2020, 05:32:13 PM
Thankyou. I had it fixed in a couple hours. Excellent thread. :152:
Offline UnmzldOx
Reply #4 on: July 04, 2020, 03:25:54 PM
Glad it helped.
Offline FreoDocker
Reply #5 on: October 19, 2020, 01:09:57 PM
Hi mate, I have that faulty fuel gauge issue. Constant bars going. I have had the issue for  over 2 years now. Can you tell me how to fix it please ? This is the only issue I have ever had with my bike. I bought it new 2014 model. Can you help thank you.
Offline HondaRebel
Reply #6 on: October 19, 2020, 01:30:18 PM
*Originally Posted by FreoDocker [+]
Remove your fuel tank, then remove the sender unit and solder a wire on.
https://www.cb500x.com/index.php/topic,6869.0.html
Reply #7 on: October 19, 2020, 04:23:54 PM
If you go into Valve Clearance- How to under Maintenance and Servicing, this thread will show you how to remove your tank. Then just a matter of removing the sender and soldering the wire back on.
Offline FreoDocker
Reply #8 on: October 20, 2020, 12:21:20 AM
 :002: thanks mate, hopefully that's the issue ill do this weekend & let you know how it goes cheers.  :763:
Offline FreoDocker
Reply #9 on: October 20, 2020, 07:37:54 AM
Ok decided to tackle this issue today. Pulled tank almost off. Checked wiring & found all in place no broken wires anywhere i can see. So does that mean its the whole unit I have to replace guys ?
