Author Topic: Water pump oil leak  (Read 15028 times)
Re: Water pump oil leak
Reply #30 on: July 04, 2020, 11:49:56 AM
*Originally Posted by STOKIE [+]
in fact I think there was a picture on here that showed metal particles in a water pump
Yes - it was my pump - a lot of metallic chips inside. In my case for sure it was the cause of pump leakage. Drained the coolant and replaced the pump - so far so good. 18000 kms and no trace of leakage anymore.
Online STOKIE
  • Bike: 2020 CB500X
Reply #31 on: July 05, 2020, 07:58:41 AM
How many mile's on yours before it started leaking.
Reply #32 on: July 05, 2020, 10:27:11 AM
28000kms. However mine started to leak slightly brand new, stopped with 1500 and started again at higher rate with 28000.
Last Edit: July 05, 2020, 11:02:45 AM by timur
Offline nicholas
  • Bike: cb500x
  • Country: gr
Reply #33 on: July 09, 2020, 02:02:23 PM
I'm of a different mind, having been in motor vehicle technology most of my life and having seen some of the things that can happen to engines it's really important even with modern engines to look after them early on in their life. That first oil change early on is really important, as it clears out any metal residue from manufacturing and running in. Also I change the coolant early on as well, because you will also get metal particles from machining in the waterways, in fact I think there was a picture on here that showed metal particles in a water pump, so I give it a good flush out and  renew coolant, in the big scheme of things it's only a few pounds. also I fit a magnetic sump plug you'll be surprised what that picks up. I use Honda type 2 coolant not the pro stuff, buy it from car place a lot cheaper and same spec but different color and about £15 for 5 litre. Well that's my thoughts on looking after my engine, I dare say everybody thinks differently,but that's what makes the world go round.  :158:
YES !!!
+1
type 2 is INT or OAT ?
if i remember well its an OAT correct?
i  too use toyota's HOAT coolant
for the rest fellow forumers .
im an engineer - car mechanic for 25 years now
apart from this beeing my everyday job its also my beloved hobby.
develop-build-mod-service engines.
im not promoting anybrand of coolant or oil as a fellow said ironicly.....
im giving you some good advicce about things ive seen -studied.
soooo honda says engine oil replacement should be every 12.000 km's
but im changing the oil on all my bikes in less than 6.000 km's
if i tell you to do what i do ...would that make me a promoter of .......... oil brand ?????
forums like this are here to help each other ....
i dont see the reason why one should be ironic.
and last but not  least i dont recall advising on a specific coolant brand  :084: :084: :084: :187: :187: :187: :187: :038: :038:
Offline Mister Paul
Reply #34 on: July 09, 2020, 02:17:16 PM
*Originally Posted by nicholas [+]
YES !!!
+1
Of course this forum is here to help people and keep them informed.
Which is why I would like to ask for the evidence that Honda's fluid change schedules are inadequate and likely to cause damage to our bikes?
Last Edit: July 09, 2020, 02:17:47 PM by Mister Paul
Offline nicholas
  • Bike: cb500x
  • Country: gr
Reply #35 on: July 09, 2020, 07:15:27 PM
do you follow honda's oil change instructions (12.000)? and oil filter every second oil change ?
Offline Mister Paul
Reply #36 on: July 09, 2020, 07:51:23 PM
Can you answer my question first please?
Online Neox
  • Bike: 2016 cb500x
Reply #37 on: July 09, 2020, 10:13:48 PM
the water/oil pump assembly is the same as on the 1998 model...
But the old one never had any problems with leaks at this level. Never.
I had bought mine in 2017, a 1998 model year, no leak even in a traffic jam on the German motorway with 35° and the fan that didn't stop.
I hadn't changed the coolant and had no idea how old it was. But it work well.
A magasine put one in spare parts after 300000 km, no corrosion at the pump...
Conclusion? Good quality machining or metal in 1996, bad quality machining or metal in 2016...
Offline nicholas
  • Bike: cb500x
  • Country: gr
Reply #38 on: July 10, 2020, 07:58:22 AM
That was my answer.
Offline Mister Paul
Reply #39 on: July 10, 2020, 08:31:55 AM
That was my answer.
So you acknowledge that there is no problem with Honda fluid change schedules.
Thanks for clarifying.
