Author Topic: Actual top speed cb500x 20MY  (Read 1106 times)
Re: Actual top speed cb500x 20MY
Reply #10 on: July 11, 2020, 08:57:06 PM
Back in the 70's my ratty old Triumph 500 would do the ton (indicated right enough), surely my modern Honda can top that??
Not going to try though.   :034:
So how accurate do you think those old Smith speedometer  were-if I remember right they told you if you were moving or stopped any thing else was a guess :008:
Offline japes1275
Reply #11 on: July 11, 2020, 09:36:19 PM
Actually my Smiths Chronometric from the 50s is pretty much bang on - up to 60 mph anyway, still running it in after a rebuild. Not that Id try taking it much more above that though! The speedo was serviced recently.
My later magnetic type Smiths from the 60s is still reasonably accurate but only if you read the number midway between the extremities of the needle bounces!
Offline Neox
  • Bike: 2016 cb500x
Reply #12 on: July 11, 2020, 10:35:42 PM
With this CB and all the luggages:
I took 180 km/h at 9500 rpm on on the autobahn in Germany... :156:
Online Ponzan
  • Bike: 2017 CB500XA
  • Country: cl
Reply #13 on: July 12, 2020, 05:09:57 AM
*Originally Posted by BenjaminCB [+]
With my 19 with a puig screen in the tall position I have hit a max of 165KPH on the speedo.
same around 165kmh with my 2018, on straits no wind against
Previous: NXR150, XRE300, DR400, XL500, scooters
Reply #14 on: July 12, 2020, 08:30:48 AM
1957 5TA model that I had rebuilt in 1970, so speed was probably an estimate!  But with the higher/wider bars I'd fitted, it sure felt like 100mph..... it was downhill on a motorway...... probably with a following wind!!
I once saw 100mph on my 60's Honda CB72, and my passenger was carrying a Simca 1000 silencer!!  Surprise, surprise, I later blew that engine.
In the 80's, the ton+ was easy in my Alfa Romeo 33, Suzuki SV650 too, but I've calmed down a lot since then.  :164:
Last Edit: July 12, 2020, 08:35:02 AM by AJC500
Reply #15 on: July 12, 2020, 12:09:02 PM
Takes a very long time to get to 100 mph. I was sat watching the speedo gradually get higher.
94....... 95........ 96......  :139:
My 1300 reaches 100 in the blink of an eye and still pulls like a train  :046:
Reply #16 on: July 12, 2020, 02:00:55 PM
When you said CB72 I had a flash back-I had a CB77-that was the bike of the day-untill the Suzuki 250X6 came out in 1966 and blew it away--the good old days I really miss them
Reply #17 on: July 12, 2020, 05:09:12 PM
Rebuilt from scrap in the late 70's, sprayed in original Honda red.  :152:
Offline barko1
  • Bike: 2020 500x
Reply #18 on: July 13, 2020, 04:43:10 AM
First hit the ton on a CB77, had an X-6 at some point as well.
Reply #19 on: July 13, 2020, 05:50:33 AM
*Originally Posted by barko1 [+]
Four things I remember about the X6 power band about 2'' wide- mushy shifting trans felt like your toe was in mash potato's-funny shaped plastic headlight and the best was the gas cap which was just a big rubber plug with a big S on it- you just pushed it in no turning-on a hot day if you left the bike in the sun the cap would just pop out--yup those were the days
