Search
Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Coolant usage  (Read 18229 times)
Offline O8ride
  • On life's long journey
  • Bike: Honda CB500X
  • City / Town: Harrogate
Re: Coolant usage
« Reply #20 on: June 11, 2015, 05:32:40 PM »
Thanks everyone and sorry for opening back up an old thread. Found that one of my local bike shops that focuses on cheap Chinese stuff now used to be a honda dealer and he had some blue castrol coolant that he always uses and mixes without any problems. Moreover, the bottle has an extendable spout that meant I didn't have to remove the side panel or buy some hose. Result!
Offline blowpipe
Re: Coolant usage
« Reply #21 on: June 11, 2015, 08:16:14 PM »
Just checked mine on the back of this, and yes the level was well below the minimum level, only marginally above the outlet pipe at the bottom. Warmed it up to working temperature and it only lifted by a fraction. Just over 3,000 miles on my 2013 CB, never lost a drop on my 40,000 mile VFR.
Mr Honda, think you have a problem here.
« Last Edit: June 11, 2015, 08:37:34 PM by blowpipe »
Offline ngling
  • City / Town: Rockhampton
Re: Coolant usage
« Reply #22 on: June 12, 2015, 10:08:48 AM »
Done nearly 12.000 km on my X and coolant has not changed at all. Considering I ride in pretty warm conditions, that's pretty good.
Re: Coolant usage
« Reply #23 on: June 12, 2015, 03:48:01 PM »
Yes but few do.Most have a no loss closed cooling system.My '98 Cavalier does and it's wonderful.Other than a flush and fill ever five years,I never touch the cooling system.I usually change the hoses and serpentine belt then.
We maybe talking about 2 different things  I'm referring to radiator recovery systems used on water cooled engines  All cars since mid 70's and all water cooled motorcycles(road bikes) use recovery systems  they have to a sealed system would blow up when the pressure rises   the coolant has to go somewhere it goes in the recovery tank and is pulled back in the radiator when the pressure reverses    this includes your 98 GM  you might not need to touch it  but it's still there   the only water cooled bike that I can think of that did not let you add coolant to the tank itself is the 1972-77 GT750 Suzuki you added through the radiator cap
« Last Edit: June 12, 2015, 05:02:26 PM by motorboy »
Offline Defender
  • Bike: Yamaha YBR
  • City / Town: Pwllheli
Re: Coolant usage
« Reply #24 on: June 12, 2015, 05:06:07 PM »
I agree with motorboy, every liquid cooled engine I've ever seen has an expansion tank of necessity as liquid coolant expands when heated. The tank will usually have min and max levels marked on it. A totally closed or sealed system would go bang when heated, as the coolant has nowhere to expand to, unless like central heating there was a flexible diaphragm to allow for this. If so It's a new one on me. Any system will incur loss if it leaks.
  • Wrecked Wrench Motorcyclist
  • Bike: 2014 CB500XT
Re: Coolant usage
« Reply #25 on: June 12, 2015, 05:46:44 PM »
Correct.Close system use the air,or head space,in the coolant recovery tank to prevent overflow.My car has a closed system.The radiator has no fill cap.My coolant recovery tank has an 18psi cap.When the pressure reaches 18psi,it vents air above the coolant in the recovery tank.When it cools down enough to create a vacuum,it sucks air back in.No coolant ever passes the cap in my system,unless the cap is faulty.
This is not my car but mine is identical to the Cavalier.
Artist also known as ben2go.
Current bikes
Offline Defender
  • Bike: Yamaha YBR
Re: Coolant usage
« Reply #26 on: June 12, 2015, 06:39:36 PM »
Way back when, the radiator itself had space at the top which performed the same function as a header tank, or expansion tank, as it allowed space for expansion. Probably changed to separate tank to permit lower bonnet lines to reduce drag coefficients.
Re: Coolant usage
« Reply #27 on: June 13, 2015, 05:10:49 PM »
 :028:
Current bikes
Offline blowpipe
Re: Coolant usage
« Reply #28 on: June 13, 2015, 05:47:33 PM »
Perhaps loss is down to the rubber cap on the filler tube?
Strikes me that if this doesn't make a tight seal you're going to suffer loss through evaporation.
Offline Defender
  • Bike: Yamaha YBR
Re: Coolant usage
« Reply #29 on: June 13, 2015, 07:36:02 PM »
Whatever it is, it needs investigating. There's only two places it can go, out of the system, or into the engine, which I'd guess is unlikely in this case. Any fluid loss, be it coolant, brake fluid or engine oil, needs looking at, in my opinion, if only for reassurance.
