Author Topic: 2 year brake bleeding  (Read 2295 times)
Offline Markdarren
  • Bike: CB500x
on: March 20, 2017, 10:15:36 PM
How do you do a 2 year brake bleed on a X with ABS.
1)The old fashion way, add fluid to the reservoir & pump.
2) Take the bike to Honda and they connected to a computer and place it in drain mode to bleed.
Offline jsonder
Re: 2 year brake bleeding
Reply #1 on: March 20, 2017, 10:31:07 PM
I did it the old fashioned way, installing speed bleeders and adding new fluid to the master cylinders.  It took a lot of bleeding to get the rear brake firm again, I used maybe 4 ounces on the rear and did the front brake and the CRF230L brakes using 4-5 ounces.  The dirt bike does not have ABS.
Offline Gills
  • Bike: 2013 CB500XA
Reply #2 on: March 21, 2017, 09:02:44 AM
Agreed - old fashioned way is fine. The only caveat I would add is for ABS bikes; if there is any muck/rubbish in the reservoir, suck is out with a syringe rather than pump it through the ABS plumbing.
Offline drjack
Reply #3 on: March 21, 2017, 10:28:44 AM
I use the reverse bleeding/flush method. When I first empty the reservoir I wipe it clean to get any gunk out of it. Here's a link showing how to do it.
Offline Dukie
  • Bike: Cb500x
Reply #4 on: March 23, 2017, 07:40:47 AM
*Originally Posted by drjack [+]
As above. Works perfectly.
Sold:  '13 Rally Raid lvl 3.
own:  '17  Rally Raid lvl 1
Offline cwjb
Reply #5 on: March 23, 2017, 02:14:12 PM
Interesting. The only thing I would add is to use a JIS screwdriver on the master cylinder cover. You can also get JIS bits for an impact driver.
Offline Poppy
Reply #6 on: March 23, 2017, 11:21:47 PM
Good info drjack. When the time comes, I'll use that method.
Thanks
