Basic Search
Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: 2 year brake bleeding  (Read 2035 times)
Offline Markdarren
  • Bike: CB500x
  • City / Town: Hampshire
« on: March 20, 2017, 10:15:36 PM »
How do you do a 2 year brake bleed on a X with ABS.
1)The old fashion way, add fluid to the reservoir & pump.
2) Take the bike to Honda and they connected to a computer and place it in drain mode to bleed.
Offline jsonder
Re: 2 year brake bleeding
« Reply #1 on: March 20, 2017, 10:31:07 PM »
I did it the old fashioned way, installing speed bleeders and adding new fluid to the master cylinders.  It took a lot of bleeding to get the rear brake firm again, I used maybe 4 ounces on the rear and did the front brake and the CRF230L brakes using 4-5 ounces.  The dirt bike does not have ABS.
Offline Gills
  • Bike: 2013 CB500XA
  • City / Town: Chesterfield
« Reply #2 on: March 21, 2017, 09:02:44 AM »
Agreed - old fashioned way is fine. The only caveat I would add is for ABS bikes; if there is any muck/rubbish in the reservoir, suck is out with a syringe rather than pump it through the ABS plumbing.
Offline drjack
  • Bike: 2016 CB500X
  • City / Town: Lawrence, KS
« Reply #3 on: March 21, 2017, 10:28:44 AM »
I use the reverse bleeding/flush method. When I first empty the reservoir I wipe it clean to get any gunk out of it. Here's a link showing how to do it.
The intelligent rider uses a quiet pipe.
Offline Dukie
  • Bike: Cb500x
« Reply #4 on: March 23, 2017, 07:40:47 AM »
*Originally Posted by drjack [+]
As above. Works perfectly.
Sold:  '13 Rally Raid lvl 3.
own:  '17  Rally Raid lvl 1
Offline cwjb
  • City / Town: Wilmington, IL
« Reply #5 on: March 23, 2017, 02:14:12 PM »
Interesting. The only thing I would add is to use a JIS screwdriver on the master cylinder cover. You can also get JIS bits for an impact driver.
Offline Poppy
  • City / Town: Valencia, Calif.
« Reply #6 on: March 23, 2017, 11:21:47 PM »
Good info drjack. When the time comes, I'll use that method.
Thanks
