Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Gear Indicator  (Read 4266 times)
Online SnowOwl
  • Gender: Male
  • Bike: 2016 CB500XA
Gear Indicator
« on: May 03, 2017, 03:07:45 PM »
I have recently gotten back to riding after 35 years.  I've put a bit over 1000 miles on the bike so far and at times have had a little difficultly with figuring out what gear I'm in.
There are times that I don't get a solid click when shifting and it's unclear if it actually changed gears or not, so it throws off the mental gear count.  Then there are times when slowing down for a turn I really need to make sure I'm in 2nd gear and not 1st so I don't excessively engine break going into the turn and dump the bike.  To be sure its in 2nd I sometimes will shift down to 1st and back up to second, this takes time I don't always have in traffic.  Of course, there are also all the times trying to shift into 7th gear because I'm not certain if its in 6 or not.
So, I decided it was time to install a gear indicator.  I got the less expensive "iDea" brand off of eBay.  It plugs into the diagnostics port under the seat.  Last evening the weather finally cooperated and I took a nice long 1-1/2 hour ride in the country checking out all the flooding currently going on.  What a difference it makes knowing for sure what gear it's in!  This greatly increases confidence and decreases clutch wear.  The gear indicator is very easy to install and doesn't cost a lot.  It is well worth in in my opinion.  If you have been wondering if you should install one, I would highly recommend it.
1982 Suzuki PE175
2016 Honda CB500XA
Offline KMGuy
  • Gender: Male
Re: Gear Indicator
« Reply #1 on: May 03, 2017, 08:13:49 PM »
The gear ranges are fairly narrow on the X so I've considered it myself, I've heard of people having a mixed bag of results with the quality of the less costly Chinese import units though. I'm looking to add this and self-cancelling turn signals this season, let us know how it goes!
Offline Tom A.
  • Gender: Male
Re: Gear Indicator
« Reply #2 on: May 17, 2017, 08:35:00 PM »
Do you have a link to the eBay item please  ?
Online SnowOwl
  • Gender: Male
Re: Gear Indicator
« Reply #3 on: May 17, 2017, 08:38:34 PM »
This is the one I got:
>>>> link hidden <<<<
You can search "Honda gear indicator" to see all the types that are available.
1982 Suzuki PE175
2016 Honda CB500XA
Offline Nortoon
  • Gender: Male
  • Bike: 2013 CB500XA
  • City / Town: Ottawa
Re: Gear Indicator
« Reply #4 on: May 17, 2017, 09:04:20 PM »
*Originally Posted by SnowOwl >>>> link hidden <<<<
I had a 25 year hiatus before returning to motorcycling, and bought a digital gear indicator for the same reasons you did. Some pooh-pooh the idea saying it isn't necessary, but it sure makes riding a lot easier.
Great buy BTW, I paid 4 times that for my GIpro-DS.
« Last Edit: May 17, 2017, 09:07:13 PM by Nortoon »
Offline mark444
  • Gender: Male
  • Bike: '14 White CB500X
  • City / Town: Burpinham, Bama
Re: Gear Indicator
« Reply #5 on: May 17, 2017, 09:13:55 PM »
I installed the China Version ($36 a year ago) and have had no problems with it. I did make a tiny sun-shade to enclose it some due to sunlight.......depends on where you have it mounted I guess. Mine is on the front brake reservoir.......some members mount theirs down in the console (in the shade??).
I ignore the comments about "not" needing one. I don't HAVE TO HAVE one, I just like using it, personally. I compare it to a Tachometer: everyone can ride a bike without a Tach, but it sure is nice having one..........
Currently: 2014 CB500X, 2008 WeeStrom, (2) 1996 GPZ1100, (2) ZX11's, 1994 CBR1000F, 1972 Honda CB750, & 1979 CSR650 Kawi.
Offline Pigeonherd
  • Gender: Female
  • City / Town: Quincy, CA
Re: Gear Indicator
« Reply #6 on: May 17, 2017, 10:57:35 PM »
I'm almost afraid to ask (in case the answer is 'no'), but is this a plug&play item??
>>>> link hidden <<<<
Guest - The above link is visible to MEMBERS only. Please Register or Login>>>> link hidden <<<<
Offline yojimg
  • Gender: Male
  • City / Town: San Francisco
Re: Gear Indicator
« Reply #7 on: May 17, 2017, 11:12:07 PM »
 Yes, it connects to the diagnostic connector under the saddle, and you route the wire up under/around the gas tank to the dash or wherever you want to locate it, and it mounts with double-sided tape.  Couldn't be simpler.
>>>> link hidden <<<<
Guest - The above link is visible to MEMBERS only. Please Register or Login by >>>> link hidden <<<<
Guest - The above link is visible to MEMBERS only. Please Register or Login, on Flickr
Online SnowOwl
  • Gender: Male
Re: Gear Indicator
« Reply #8 on: May 18, 2017, 12:47:49 AM »
It does need to be calibrated.  It's a very simple procedure, especially if you have a center stand.
1982 Suzuki PE175
2016 Honda CB500XA
Offline barndog
  • Gender: Male
  • Bike: cb500x
  • City / Town: belfast
Re: Gear Indicator
« Reply #9 on: May 21, 2017, 09:23:48 AM »
Ive had my eye on one of these for a while, ill have to order next pay day
