Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Gear Indicator  (Read 4282 times)
Offline Uncle Tee
  • Gender: Male
  • City / Town: Memphis
Re: Gear Indicator
« Reply #10 on: May 23, 2017, 06:23:18 AM »
I see a near future not trying to shift into seventh gear. :046:
Farkles: A silly little word for things I know nothing about until I read another post and wonder "Why in the world have I not gotten this yet?"
Offline Bern_Grt
  • Gender: Male
Re: Gear Indicator
« Reply #11 on: June 04, 2017, 06:06:23 PM »
Ordered one from Amazon late Friday... Delivered this morning  :002:... and fitted in ~30mn just before heading off for work  Definitely handy to have :305:
Bern.
Offline Sargent_Horse
  • Gender: Male
  • What's brown and sticky? A stick!
  • City / Town: Mesa, AZ
Re: Gear Indicator
« Reply #12 on: June 04, 2017, 06:54:45 PM »
This is the indicator I have. I don't have the bar mount though I have included it because it may be something some may want.
+160 GIPRO Gear Indicator (Red) >>>> link hidden <<<<
+60 Gear indicator mount (Black) >>>> link hidden <<<<
I don't actually own a vehicle with more than 2 wheels...
Offline dnu69
  • Gender: Male
  • City / Town: Federicton
Re: Gear Indicator
« Reply #13 on: June 05, 2017, 01:35:12 AM »
They are great.  I have one from ebay (china as well).  Find I use it a lot.  I have mine on the right of the main display.  Drilled a small hole, took the connector apart, installed a grommet and fed the cable through.  Install and program is pretty simple.
Offline Ponzan
  • Country: cl
  • Gender: Male
  • Bike: 2017 CB500XA
Re: Gear Indicator
« Reply #14 on: July 05, 2017, 01:07:55 AM »
I found the best spot to install this gear indicator may be at the top of the lid that gets you to adjust the headlight aim, just under the Instruments panel. Easy to install; just remove the lid and drill a hole for the cable and use the supplied double tape. It looks great: clean, easy to peek, natural position, sun shaded
CB500XA; XRE300; HJ125 scooter. Previous: NXR150, DR400, XL500
Offline WildGig
  • Gender: Male
  • City / Town: Gold Coast
Re: Gear Indicator
« Reply #15 on: July 07, 2017, 06:23:59 AM »
For those of you who have one of these installed; I understand that the change is only indicated when you let out the clutch.  So, what happens if you, say, change down two gears without releasing the clutch in between? Does the indicator track the changes but only display the correct gear when you release the clutch?
Cheers
Offline Bern_Grt
  • Gender: Male
Re: Gear Indicator
« Reply #16 on: July 07, 2017, 08:05:42 AM »
*Originally Posted by WildGig >>>> link hidden <<<<
Cheers
I have one of those "generic" indicators and yes, it displays the correct gear after having shifted down 2 or more at a time.
Bern.
Offline WildGig
  • Gender: Male
Re: Gear Indicator
« Reply #17 on: July 07, 2017, 10:48:26 AM »
Thanks  :152:
Online SnowOwl
  • Gender: Male
  • Bike: 2016 CB500XA
Re: Gear Indicator
« Reply #18 on: July 07, 2017, 02:26:53 PM »
The device reads the engine RPM's and speedometer signals from the ECM.  You do a simple calibration when you install it so it can learn the ratio of each gear.  When the clutch is engaged and there are valid signals for RPM and speed the device calculates the gear you are in and displays it.  When you pull in the clutch the display for the last gear you were in persists for a second which gives you time to glance at it and see what gear you are shifting from to do your mental count before you let the clutch back out.  After the second of persistence it displays a dash until you let the clutch back out.  It also displays a dash when in neutral since there is not a valid ratio being read from the ECM signals.
1982 Suzuki PE175
2016 Honda CB500XA
Offline WildGig
  • Gender: Male
Re: Gear Indicator
« Reply #19 on: July 17, 2017, 02:50:09 AM »
Thanks for the detail SnowOwl  :001:
