Search
Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: when to shift  (Read 1751 times)
Offline dpwell
  • City / Town: Vancouver BC
when to shift
« on: July 13, 2017, 08:57:37 PM »
hi - I like to ride around 50 - to 55 km/hr in the city. By the time I reach 50 I'm usually in 3rd at around 4000 rpm, but I sometimes think I'm lugging the engine. So I started experimenting with staying longer in 2nd. If I stay in 2nd I'm up to around 5000 rpm at 50 km/hr and I can hear the engine, though I'm nowhere near the redline. The manual's guidance on this strikes me as odd, as they seem to recommend shifting speeds that are much lower than speeds I would shift at. E.g. it recommends going from 2 to 3 at 30 km/hr.
My bike is also quite buzzy and vibrates a fair bit (this is only my 3rd bike ever and the previous 2 were small sport bikes that were smoother - I've never ridden a thumper or other very vibrating bike). I've read some other posts here about this. Perhaps I need to work the engine in a bit more by getting the revs up over 5000 a bit more often? I'm noise-averse so I tend to prefer to ride at lower rpms where I can't really hear the engine too much but maybe I need to change that.
I'm curious to know what thoughts you all have about when to shift.
cheers.
  • Wrecked Wrench Motorcyclist
  • Bike: 2014 CB500XT
Re: when to shift
« Reply #1 on: July 13, 2017, 09:47:01 PM »
I find the optimum shifting for me is between 4-5000 rpm when I'm around town. Maybe as high as 6000 rpm on some of the hills. Your gear and weight will make a difference as to when to shift. A 130lb person won't need to shift as high in the rpm range as someone big like me that is 230lbs and carriers 60lbs of gear.
Artist also known as ben2go.
Current bikes
Offline drjack
  • City / Town: Lawrence, KS
Re: when to shift
« Reply #2 on: July 13, 2017, 10:58:00 PM »
For casual on road riding I usually stay between 3-5K rpms. There is a bit more vibration the higher the rpms are and the fuel economy suffers too. Below 3K the engine lugs. For cruising at a fairly steady speed I run 3500-4K, mostly for fuel economy. But acceleration isn't great at those rpms. Above 5K it pulls really well.
Jack
Re: when to shift
« Reply #3 on: July 30, 2017, 05:12:09 PM »
Just been out on the bike, and tried to assess gears and revs for low speeds -
Out on Motorways, or A and B roads I find that 6th allows the bike to be almost like an automatic, pulling without jerking from as low as 30mph/2500 revs, although I would normally change down to 5th for 30mph village speed limits and for quicker overtaking.
4th seems able to pull acceptably about town from 20mph/2500revs, and easily from 25mph/3000revs, although again I would normally use 3rd if I was as low as 20mph, for more flexible throttle action.
1st and 2nd are almost like 'pulling away' gears for me, maybe using 2nd for right angle junctions at slow speed.
I am quite a gentle rider, I must admit, but these speeds/revs are smooth, and match car traffic and speed limits easily enough, although like Jack I do tend to change gear if dropping below 3000revs, and around 5500revs on the way up.
I find holding onto gears at higher revs might make fast acceleration easier but throttle control is more jerky.......maybe that's why I'm averaging 90mpg!! :001:
Anyway, there you go!
20mph - 32kph
30mph - 48kph
50mph - 80kph
Re: when to shift
« Reply #4 on: July 30, 2017, 07:17:59 PM »
Stop looking at your speedo and start feeling your bike. No one can tell you when to shift, only the bike can. Learn the bike, feel when it wants to shift based on conditions and when the rpms are too low for the gear you're in. Go enjoy your bike and have fun.
Re: when to shift
« Reply #5 on: July 30, 2017, 07:29:45 PM »
20mph - 32kph
30mph - 48kph
50mph - 80kph
This is very much how I ride my bike.
Re: when to shift
« Reply #6 on: July 30, 2017, 07:34:54 PM »
Absolutely agree, I just thought I'd look at these gears/speeds/revs figures for the sake of our friends question.  :034:
Re: when to shift
« Reply #7 on: July 30, 2017, 07:43:04 PM »
I'm all about good information but certain things should not be over thought.  :002:
Offline dpwell
Re: when to shift
« Reply #8 on: July 30, 2017, 08:21:10 PM »
thanks everyone for all the info. Yes, some things should not be overthought and for sure shifting is one of them!
I'm getting used to the Honda after 7 years of riding a Ninja 250, which obviously lives at a much higher rev range, so I'm getting used to shifting at lower revs. I like the idea of 90 mpg. I don't think I get anything near that.
20mph - 32kph
30mph - 48kph
50mph - 80kph
so are these the speeds you are shifting into 4th, 5th, and 6th?
Re: when to shift
« Reply #9 on: July 31, 2017, 09:35:15 AM »
*Originally Posted by dpwell [+]
Nope, these are not speeds I'm changing at, just the minimums that my bike was happy at - as our friend says, I just go by feel!!
I now see the problem though - I tested a Kawasaki 250 a while back and felt I was always revving the nuts off it.  I couldn't handle thrashing a bike like that to get at the performance, the X is a much gentler beast.....
