Search
Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: abs light?  (Read 587 times)
Offline papateo02
  • Country: gr
  • Bike: cb500x
  • City / Town: thessaloniki
abs light?
« on: August 11, 2017, 11:27:51 AM »
does your abs light comes on when you are at fully stop?  :435:
cause i think mine is not coming on its always engaged
Online HerrDeacon
  • Bike: 2014 CB500X ABS
Re: abs light?
« Reply #1 on: August 11, 2017, 11:57:31 AM »
The ABS light should light up when you first start up the bike, but then once you start moving it will turn off (over some speed, I think around 10 km/h). It won't come on again until you either shut off the bike and start again or if there is a problem with the system.
'14 CB500X / '82 MB5 / '78 XL250S / '72 CB350
Riding Through the Fog
Offline papateo02
  • Country: gr
  • Bike: cb500x
Re: abs light?
« Reply #2 on: August 11, 2017, 12:04:46 PM »
*Originally Posted by HerrDeacon [+]
i thought it comes on when you are at fully stop, or when going too slow, i tried to warm up my back tyre  :124: but front abs wont let me  :003:
Re: abs light?
« Reply #3 on: August 11, 2017, 01:45:26 PM »
The ABS light will be on when you first start the bike.  It will turn off once you go above 6 mph or 10 km/h.  It will not turn on again unless there is a fault in the system or the key is turned off.
The ABS system is only active when moving above 6 mph or 10 km/h.  You can check this by mashing down hard on the rear brake when you go below that speed, the rear tire will lock up.  I wouldn't try that with the front tire unless you want to do a low speed high side.  So when you drop below that speed it will become inactive but the light will remain off.  The light is only for indicating a fault in the ABS system.
Offline hilldweller
  • City / Town: Macclesfield
Re: abs light?
« Reply #4 on: August 11, 2017, 05:17:41 PM »
*Originally Posted by papateo02 [+]
Definitely not.
Brian.
