Search
Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: DashCam equivalent.  (Read 999 times)
Offline macamxthe1st
DashCam equivalent.
« on: August 11, 2017, 12:15:55 PM »
Like many others these days we have a DashCam fitted in our car and it recently proved invaluable in a minor accident when the other driver failed to stop. I wish for a similar arrangement on the bike. I do not want a helmet camera but a unit that can be attached permanently to the bike run on a "loop" system and be powered from the bike and activated, deactivated when the ignition is switched on/off. Started looking this morning and it's a nightmare. If anyone has a similar set I would dearly like to hear from them. Thanks.
Geoff.
Heated grips, gear position indicator, grip puppies, fenda extenda, tank protector, Michelin PR4's with "Tyre seal installed", shaved seat, rack and Givi Blade top box, rear hugger, sidestand plate, center stand, Hawk accessory bar with spotlights, Daneli mini soundbomb, Givi XS319 tanklock bag, loobman oiler, Evotech radiator guard, Fuel Micro Mini minus baffle and a liberal coating of Acf50 oh and a detachable sheepskin seat pad, lovely.
Offline Sargent_Horse
  • What's brown and sticky? A stick!
  • City / Town: Mesa, AZ
Re: DashCam equivalent.
« Reply #1 on: August 11, 2017, 04:40:01 PM »
I have never used a dashcam, but don't they just plug into a 12v plug? So you could hook one up to an OP plug and mount it to your wind screen.
I don't actually own a vehicle with more than 2 wheels...
« Reply #2 on: August 11, 2017, 04:49:57 PM »
That is indeed the case. It is the choice of camera that I am struggling with.
Geoff.
Offline Ceddy17
  • Country: be
  • Ed
  • City / Town: Geel
« Reply #3 on: August 11, 2017, 04:54:03 PM »
Yep, I got one!
I experimented with an action cam put in loop mode (Ricoh WgM1) but had battery problems amongst others...
Now I use a cheap Blacksys BH-300 that I modified a bit.
Stuck it to the dash behind the screen and taped everything shut to prevent rain coming in (not really waterproof cam).
Don't expect high resolution video. To see the film, you have to take the micro sd card to a computer and view the files with a special tool, delivered with the cam.
The micro sd card is also formatted in a special format so you can't do anything else with it, besides stick it in the cam.
It is connected to a switched power outlet (12V) and easily taken off and on the dash to prevent theft.
Works fine for me, but I only use it in case of a despute or an accident or so... certainely not to stream it to youtube or the like...
There is only one glitch: the camera often thinks there is an incident (because of the vibrations of the bike) en saves that recording on sd card.
I have to reformat the card every two weeks or so, but I can live with that...
Good luck with the search...
Ed.
Offline Irishrover
  • Bike: CB500X/CB400SF
  • City / Town: Falkirk
« Reply #4 on: August 11, 2017, 04:57:37 PM »
*Originally Posted by macamxthe1st [+]
Geoff.
Most of the helmet cams have that feature. I have the Gitup Git2 and it has a dash cam function, I've never used it though, but it can be permanently powered and erases the footage each time you restart the engine. You can mount it in its waterproof case on the bike instead of a helmet.
Offline dnu69
  • City / Town: Federicton
« Reply #5 on: August 15, 2017, 02:10:34 AM »
I use a Mobius on the rear and Mobius Mini on the front.  Both set up in loop mode, come on when I start the bike and shut off 20 minutes after I shut the bike off.  The Mini is a great camera.  The only down side is rain.  The back one is mostly protected because of where it I mounted, the front one I just put a bag over it or take it off.  Tend to avoid the rain most of the time anyway.
Offline Irishrover
« Reply #6 on: August 15, 2017, 09:35:17 PM »
*Originally Posted by dnu69 [+]
I also have a Mobius. Great very small camera and good footage once you mess around with the software settings. You can get a waterproof case.
Offline jonathan101514119
  • Bike: '15 Honda CB500X
« Reply #7 on: October 28, 2017, 12:40:00 PM »
If you have a phone mount on your bike you can run one of the many dashcam apps available in the Google Play Store or Apple Store. Just read the reviews and descriptions of each one to make sure you get one that meets your needs the best.
