Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Doing cheap suspension upgrade (racetech forks and GSXR shock) - Tips?  (Read 14990 times)
Offline BigShot
  • City / Town: Hanford
I just finished installing the Racetech springs .75kg and a 2001 GSXR600 shock today. Can I just say WOW, what a difference from stock.  The bike feels more stable, planted and I feel more in control.  After the work was done I couldnt help myself but take it on a local dirt road for an evaluation and I am happy with the results.  The fork springs are much more responsive and the spring quality is evident. The rear shock actually  has dampening characteristics including  adjustability and the spring weights are very balanced from front to rear.  The only difficult part is cutting part of the plastic fender to fit the shock, be careful  there is a wire that is above where you need to cut.
Fork oil 10wt 130mm from top, Race Tech .75kg constant rate springs, 15mm preload
2001 GSXR600 Shock that raised the seat by 3/4 inch
 I weigh 240 pounds and only ride paved, dirt and gravel roads.
 There are a few instructional videos on YouTube
Offline Sherloc
  • City / Town: KCMO
Re: Doing cheap suspension upgrade (racetech forks and GSXR shock) - Tips?
« Reply #61 on: September 11, 2019, 03:29:10 AM »
Nice work, sounds like what I need. What spring rate are folks using with the GSXR 750 shock? Is it stock length or longer? Im 230 with gear, figure 60 lbs of added luggage.
Thanks!
« Last Edit: September 11, 2019, 03:58:52 AM by Sherloc »
Offline Bradmeister
  • Springs and Sprockets
  • City / Town: Bangkok
« Reply #62 on: September 13, 2019, 06:31:32 AM »
Ignorance is Bliss
You are not "UPGRADING ON THE CHEAP" you are hacking your bike by shot gunning some new and used parts at it, and praying it's better.
Your Spring rate for 260lbs is too low at .95kg/mm and I'm guessing Race Tech does not have one ..........But Promoto, Wilbers and Hyper Pro does.
Really? A Used Track Bike Shock on a Sit Up bike with 27degree caster and a 110 trail?  Whats the Spring Rate of that Shock?  Whats the Seat height and did you have the shock Dyno tested? Or again, spray and pray?
Again, you could have spent 500 bucks and bought the correct springs and a shock with adj. Pre load, and rebound that would have been a great set up, and a well performng suspension.
Ignorance is bliss
2009 BMW K1200 GT, 2013 Kawasaki 650 Ninja,
(2)2015 Honda CB500X, 2013 KTM 350 SXF, 2013 CBR250R
2014 KTM 250 SX, 2007 KTM 250 SXF
2013 Husqvarna 125 TE, 2014 Kawasaki 140L, 2015 125 MSX, 2016 Click125
