Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Chain kit lifespan  (Read 16250 times)
Offline thefip
  • Bike: CB500X 2017 ABS
  • City / Town: Brussels
Chain kit lifespan
« on: October 29, 2017, 05:05:12 AM »
Dear all,
what is your average chain kit lifespan?
Thanks for sharing your experience.
Offline glencoeman
  • City / Town: Stoke on Trent
Re: Chain kit lifespan
« Reply #1 on: October 29, 2017, 07:29:18 AM »
It depends on a number of things really. If you clean and lubricate the chain regularly and not go off road, it will last easily for 12,000 miles (about 18,000 kms) - even more if ridden gently. However, if you neglect the chain maintenance, it will wear out a lot earlier than 12k miles. It is really up to each owner how they treat and ride the bike as far as chain life goes. When the chain does wear out, it makes sense to uprate to a higher spec than the OE chain ( I use DID chains)but you can use original OE sprockets.
Offline enterprise-psi
  • Country: gr
  • A majestic sight we must be
  • Bike: CB500X 2016
  • City / Town: Athens
« Reply #2 on: October 29, 2017, 12:27:00 PM »
My first chain lasted 15.000 km , but i only oiled it twice, and cleaned it once.  :008:
Now , im oiling every 500km, and cleaning every 1000.
Offline jsonder
  • Bike: Honda CB500XA
« Reply #3 on: October 29, 2017, 03:40:02 PM »
There have been a lot of comments about the quality of the OEM chain.  Mine had two stiff links as delivered new.  At 15K miles I decided to test the Delboy's Garage thesis that changing the drive sprocket early would extend chain life.  Medical problems kept me off of the bike much of the summer, but I have added another thousand miles to the chain.  It is still tight on the rear sprocket, so wear appears to be minimal.  I lube frequently with ATF.
Offline reavsie
  • Bike: 2014 CB500X ABS
  • City / Town: Dartford
« Reply #4 on: October 30, 2017, 03:47:33 PM »
Scottoiler and regular cleaning:
OEM chain so far on 34,700 miles and still in the green on the wear marks.
Offline marktbike
  • Country: it
  • Bike: 2015 CB 500 X
  • City / Town: Alcamo
« Reply #5 on: October 31, 2017, 09:06:53 AM »
I had to change it at 20,000 km not because of wear but because of stiff links. The OEM chain was really cheap and regular lubrication didn't help to prolonge its life, even in absence of any off road use.
Offline UnmzldOx
  • City / Town: Deep South
« Reply #6 on: November 09, 2017, 04:03:30 AM »
28 kmiles on OEM chain. Spray with Lucas daily after 55 mile commute. Rarely clean anymore. That might just drive grit into gaps that tend to stay grit free by normal lapping action when running. Maybe 1 or 2 mm adjustment so far. Watching one stiff link, but seems to be ok.
Offline jsonder
« Reply #7 on: January 21, 2018, 06:16:31 PM »
Here's the link to the Delboy's Garage video on chain life and front sprocket replacement:
https://www.youtube.com/watch?v=UxD3qdD7LhE
Offline uku383
  • Bike: 2019 CB500XA
  • City / Town: Wollongong, NSW
« Reply #8 on: January 21, 2018, 07:24:44 PM »
Delboy's changed his position on front sprocket replacement. He now advises that changing the front sprocket mid-chain life is not necessary as front sprockets are made of tougher material than they used to be.
Second bike: 2011 Triumph Sprint GT
Graveyard: 2014 CB500XA
Offline jsonder
« Reply #9 on: January 22, 2018, 03:54:48 AM »
Interesting.
Here is picture take of the 500X's drive sprocket at nearly 15K miles.  Note that some hooking is starting to develop in the drive sprocket.
I replaced the drive sprocket to see how much mileage I could get out of the OEM chain.  Still testing that.
