Basic Search
Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Has anyone tried a cbr500r or f seat on a cb500x  (Read 1365 times)
Re: Has anyone tried a cbr500r or f seat on a cb500x
« Reply #10 on: September 14, 2018, 10:15:23 AM »
Sent email with the pictures.
What's your weight loss goal with the 500x?
  • City / Town: Bundaberg
« Reply #11 on: September 14, 2018, 12:10:28 PM »
Got the pics. Really useful. Sent email reply.
No goal. Project and experiment. Look at everything an think about what can be changed and what cannot.
My last project was a GS500F. Similar goal with some updating. Ended up 20kg lighter. Lots of Aluminium for steel and carbon fibre fabrication. Here are some pics from just before I sold it.
« Reply #12 on: September 14, 2018, 01:01:28 PM »
Nice bike. It was a steal for 1600.  :-)
I think I understand.
I'm also a kind of person who always looking for things that can be improved, and as an engineer I automatically trust anyone with a lathe in the garage.
When I was racing, we used to start with removing weight from anything rotating and unsprung (wheels and brakes) first, then non-rotating unsprung (suspension), rotating masses (engine internals, clutch, etc), general "dead" weight from top and furthest of CoG to center in this order. So in principle while I would never spend money on titanium engine bolts (being expensive and very close to CoG) but would spend money and time replacing brake caliper banjo bolts and look into fitting a ligher cast alu swingarm.
I have a huge excel file subtly named as "CB500x_reengineering" on my computer with a ton of haphazad information from spring rate calculations to weight loss ordered in cost/gr, to cam profile measurements and design. Also on the cbr500r forums I have somewhat neglected topic listing weights of all OEM parts of the bike.
On my project bike (the older X) I've done the basics of de-cat headers, akra slipon, li-ion battery, etc and lost about 5 kilograms.
However I can say that while your suzuki looks like a track day bike, I'm using the X for touring so I have lot more constrains regarding usability.
So while dropping the passenger rearsets, and left side passenger rearset mount and replace the exhaust hanger with a lightweigh CF part would net a good 500gr loss of weight in total - i still need the rear pegs. Also a cnc milled rider rearset would save some significant weight I need my rearsets very sturdy. Depending the MY of your bike swapping 2013-16 (rider) rearsets to 2017+, saves about 480gr. Tried titanium platform pedals off from a YZ450R, but those are not too long living and each side worth a kidney - so sold them for the same price before they desintegrated.
Also the subframe is quite a heavy lump - replacing with one that is custom made from ally, would save some significant weight far from CoG, but I need to carry two persons and luggage - so fatigue breaks which ally is very prone of are out of the picture for me. However cutting the rearmost part of the subframe what holds the number plate normally and installing a tail tidy can also drop about 1200gr.
I'm happy to continue with other stuff on my list, but I guess we better to either continue in private or open a new topic to this.
  • City / Town: Lancashire
« Reply #13 on: September 14, 2018, 06:24:15 PM »
No....carry on in public!  :152: Always good to hear what folks are doing...
Yet to see a swingarm conversion for the off roaders...not heard any reports of the pressed steel one going pear-shaped even under duress (Tet, Tat etc.) so it may not be an issue, but a stronger, less flexible arse end is always a boon, especially if you're running a fancy shock
« Reply #14 on: September 14, 2018, 08:34:45 PM »
Actually the Suzy is set up for touring not track. The F fairing is a pretty good touring fairing and if I had kept it it would have gained a upper clear spoiler ( actually it would be a draw duct as well to stop vortex shedding). The pegs were not rearset but bio designed to be in the most neutral position. On the Suzy sheading weight was pretty easy as the bike was originally designed in the 80's and things like the footpeg assembly weighed 2.6 kg and the new aluminium based ones weighed 528grams with no loss of strength ( perhaps stronger actually).
With that in mind I looked at the pegs on the X. Just the pegs at the moment. Gives me hope for more. Stock unmolested peg weighs 334g, stripped peg weighs 77grams. Difference 257g. So 2 pegs stripped weigh half a kg with no loss of function ( I detest rubber pegs) or strength.
You say you are an engineer ( I am not, just an enthusiastic tinkerer). Are you a user of Tony Foale's suspension software?. If so do you have the datum points for the CBX500 rear suspension ( or all of them for that matter)?
I am surprised there is no "Project" area and considering the info on the forum and no stickies in the thread areas.
« Reply #15 on: September 14, 2018, 08:45:14 PM »
By the way, the single seat is a requirement for single seat registration in Queensland for cheaper registration ( really cheaper 3rd party insurance mainly). The X will be similarly shortened which also allows a better rack for touring.
« Reply #16 on: September 20, 2018, 10:57:14 PM »
Go a second hand one yesterday. FITS STRAIGHT ON! Front fit straight into the retainers. Easy to make a bracket to fit the stock key activated lock/release, even has threaded holes at the side to make a crosspiece of the lock. I can now see if I can fit my ex TR650 rear carry rack on as well.
To stop ball removal I will have to make a cover for the CX front seat hold down bracket though.
« Reply #17 on: September 26, 2018, 09:31:46 PM »
Well that was a bit easy. A 270 x35x6mm piece of aluminium two holes for 6mm bolts into the existing bolt holes on the frame and 2 x20mm spacers and 6mm bolts, through the existing seat holes at the back. . All holes in line. Done.
« Reply #18 on: September 26, 2018, 09:33:31 PM »
I can consider making a rear seat replacement cover or a rear rack with a little compartment below.
