Author Topic: Anyone interested in lightweight rear brake disc?  (Read 2461 times)
Online Oyabun
Re: Anyone interested in lightweight rear brake disc?
Reply #20 on: December 06, 2018, 10:55:00 AM
*Originally Posted by Irishrover [+]
I would have been interested if I knew it was as safe as the original and half the price. Paying 90 for a new disc isn't cheap.
But if it does the same as this piss poor after market disc, then I have concerns.
I get your point.
As for the reliability I cannot really coment other than the guy I'm working with is making small runs or one-off custom discs and sprockets for racebikes for sevaral years. He has only positive feedback and I had no such issue before as yours - but this is uncharted territory unlike the millions if mass produced oem discs what had been sold so far.
Which is the same for the cost. While it is a non-profit interest of mine it would possibly not be able ro compete with mass produced parts. My current estimate is roughly 70gbp for the disc and 10 for shipping to the UK.
Current cost is based on a minimum aggregated order of 5, and material of high carbon non-stainless material - which supposed ro have better friction properties and resistance to cracking surface treated ro peotect it feom corrosion on non friction surfaces.
Last Edit: December 06, 2018, 10:57:28 AM by Oyabun
Offline Rexelstar
  • SAME OLD DIRT, SAME OLD BIKES, SAME OLD FUN.
Reply #21 on: December 06, 2018, 10:59:38 AM
I just Love physics. My second favourite quote I usually say ro my students is that "I love physics as it is reliably fairly consistent and doesn't sleep even during weekends"
My most favourite one is that "I'm an Engineer, trasferred to the dark side of the force" having equal number of economics degrees by now than engineering (college degree in mechanical engineering, MSC in electrical engineerig, BSC in management and finance and an MBA major in innovation and technology management)
I always find new issues and questions during parting/searching/building the old school bikes.
And learned that it is difficult to find people with who you can discuss why and how it 'works'.
For example when building I found out that the inlet air tube from a XR250 Australia type is different from all other continents.
There is some sort of resonant air box attached half way on the air inlet tube...why I asked myself. So again something new to find out;)
Sorry, for going of topic!
Last Edit: December 06, 2018, 11:08:52 AM by Rexelstar
CB500XA
XL500Sa nos
XR500za Hybrid
XR250Rk nos
NX650 in progress..
Offline UnmzldOx
Reply #22 on: December 06, 2018, 11:52:35 AM
Isn't this mostly an F=ma question? A % decrease in m results in the same % increase in a. What % of the wheel mass is removed? I suspect only a fraction of a %, therefore not much acceleration improvement.
Offline 2Bpencil
  • Bike: 2016 CB500XA
Reply #23 on: December 06, 2018, 07:30:59 PM
Looks like it has 1/5 the swept surface area. Not for me. Safer to have a single instead of a double cheeseburger for weight savings.
This entertaining debate reminds me of a similar heated exchange on a bicycle forum about trimming weight - the conclusion is that it was a game of diminishing returns and ultimately better to lose a couple of pounds off your fat arse than weight-saving mods to a bike. :005:
Changing a rear disc brake for weight saving is so far down my wish list as to be off the scale. Still enjoy the design + thought that goes into it! :028:
Reply #24 on: December 06, 2018, 08:49:53 PM
Wish I hadn't seen that picture of the disc. I have just bought TWO of that brand!!!
One thing about that brand is not only is it not lighter but 400grams heavier than the stock ones ( each) , despite being labeled as lighter.
The reason is the braking surface is 20mm wider than it needs to be . This could be why it cracked. The outer part of the disc is expanding and the inner isn't, when it heats up. Mainly didn't bother because the front no centre float spider so thought wouldn't save much weight. . May have to get the brake surfaces machined down to the right width ( if it's cheap enough, one thing I cannot do myself properly) or just bit the bullet and buy EBC's.
Brake design is always a balancing act between power and modulation. Changing the pad material, disc material and/or meat in the swept area all affect it. What would be better for some may not be for others. You need to know what you want from your front or rear brake before just grabbing something. That is without even factoring in the hydraulic lever ratio ( relative sizes of the master and slave pistons).
BTW for those of you that don't ride mountain bikes, minimalist discs are very common and work VERY well. Now that doesn't mean you can do the same with a motorcycle , but MAY , depending on use.
Now I have to go away and have a little lay down to get over the cracked disc pic of my expensive purchase.
Offline Irishrover
  • Bike: CB500X/CB400SF
Reply #25 on: December 06, 2018, 10:22:57 PM
That's only one crack I'm showing on the disc mate, there are actually 3 and almost at the same point around the disc circumference. Only spotted it when I was washing the bike, thankfully that is almost weekly.
I posted this info up some time ago.  :005:
Reply #26 on: December 06, 2018, 10:39:02 PM
*Originally Posted by 2Bpencil [+]
I see your point. Much more cost effective to lose the weight yourself. But, some of us a tinkerers and some of us would prefer a lighter bike. It won't happen by one single modification, but a series of small ones.
Offline Irishrover
Reply #27 on: December 06, 2018, 10:54:19 PM
This is more important than weight saving gains in my opinion.
I was daft enough to buy an after market disc trying to save a few quid. It could have cost me my life if the disc disintegrated.
Better to stick with OEM for items crucial to the braking system.
Offline Irishrover
Reply #28 on: December 06, 2018, 11:12:43 PM
I think I would be saying, thank f$#k I did see the picture of that disc. I wouldn't put them near your bike mate.
Expensive paper weights now.
p.s. Found the original post: https://www.cb500x.com/index.php/topic,5453.msg53063.html#msg53063
Last Edit: December 06, 2018, 11:21:50 PM by Irishrover
Reply #29 on: December 06, 2018, 11:45:05 PM
I see you point.
