Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Why is the seat so difficult to replace?  (Read 2455 times)
Offline Rally Raid
  • Approved Forum Vendor
Re: Why is the seat so difficult to replace?
« Reply #10 on: December 09, 2018, 07:06:13 PM »
Trim the two plastic arms back by about 10 mm with a hacksaw and it will make it much easier to slide them in
« Last Edit: December 09, 2018, 07:06:47 PM by Rally Raid »
Online peasemold
  • City / Town: Liskeard
« Reply #11 on: December 09, 2018, 07:12:36 PM »
Are they the right-angled "hooks" that go into the square-shaped hoops?
Sounds like a plan - they're a major obstacle to fitting the seat. Thanks.
« Last Edit: December 09, 2018, 07:14:06 PM by peasemold »
Offline Bern_Grt
« Reply #12 on: December 09, 2018, 07:27:38 PM »
With the seat lined up to go back in, I push the front of the seat down and with the other hand on the rear part of the seat, push down and forward... There's a knack to it but it's also possible that as it gets used the fit loosens up a bit and gets easier to slot back in. If you have some silicone spay, applying some underneath the front area of the seat might make it slot in easier ?
Bern.
« Reply #13 on: December 09, 2018, 07:41:43 PM »
*Originally Posted by peasemold [+]
Yes - as John at Rally-Raid suggests above, if you cut those hooks about 10mm in (you can see a rib in the moulding on the underside, cut just in front of that so it's still showing/becomes the end of the hook) and it is MUCH easier to fit the seat on and off, while the hooks still locate in the loops in the frame.
Online peasemold
« Reply #14 on: December 09, 2018, 07:43:38 PM »
Brilliant - thanks for the confirmation and the extra detail!
Online peasemold
« Reply #15 on: December 09, 2018, 08:16:49 PM »
Huge thanks to John at RR for the suggestion and to JMo for the detailed explanation - the problem is solved.
Doubtless practice will speed things up, but already it's two or three attempts instead of 20 minutes of rapidly rising blood pressure.   :001: :001: :001:
  • Bike: '13 CB500X RRL1
  • City / Town: Tegucigalpa
« Reply #16 on: December 09, 2018, 09:48:37 PM »
Brilliant.  :821:
That's why I love the internet.
Online peasemold
« Reply #17 on: December 09, 2018, 09:52:33 PM »
Indeed, and forums like this one - a mine of information, knowledge, expertise and experience. It's the way people freely help each other. too.
« Reply #18 on: December 09, 2018, 09:56:09 PM »
Absolutely. I've found quite a bit of great information and advice on this site as well as other moto forums, as well as have met some fellow riders.
Offline Marv_
  • City / Town: Suffolk
« Reply #19 on: December 09, 2018, 11:08:40 PM »
Oddly, I normally find the seat a little harder to remove, than to replace (though less than 30 seconds, in each case!)
