Author Topic: Drive chain cover, can I leave it off?  (Read 2917 times)
Offline Hillie
  • Bike: 2013 CB500x ABS
on: December 10, 2018, 08:41:44 PM
I don't take my bike off road, and I'm thinking of just leaving that plastic doohickey off. Yes, it'll shield the chain, but it's very annoying that one of its bolts is blocked off by the foot peg bracket. Do folks drill a hole in that, just leave the plastic cover off, or do the whole mounting thing every time? It means the side panel and foot peg need to come off to be able to open up the chain a bit better for cleaning. Any big disadvantages I need to keep in mind in case I decide to leave it off?
Offline HerrDeacon
Re: Drive chain cover, can I leave it off?
Reply #1 on: December 10, 2018, 08:57:08 PM
I'm not sure why you need to remove the chain cover for cleaning, I just clean it from the bottom run of the chain. I've never needed to remove the cover to clean, align or even replace, the chain. With that said, you can certainly take it off shouldn't be a problem. Keep in mind though, you may get a bit of chain lube flinging around though depending on what type you use, careful it doesn't get on your tire.
Reply #2 on: December 10, 2018, 09:50:07 PM
Considering the crap that collects in there during normal use, as HD rightly points out, that crap has to go somewhere...probably over your boots  :012:. Plus there's the psychological concern of having an unprotected chain and sprocket razzing around inches from your foot  :008: not that the plastic cover would protect you any better in the highly unlikely event that should something let go
Its a bad design, I agree....drilling the footpeg bracket to gain access to that bolt may be feasible, but any hole will have to be big enough to accommodate a slimline 8mm socket. It shouldn't weaken the bracket significantly. Have a good long stare at the problem....there may be another solution...post back when you've come up with it  :028: you're right, it's an arse doing that job
Reply #3 on: December 10, 2018, 10:10:08 PM
To access the chain better I just undo the rear bolt on the chain guard and pivot it up on the front bolt.  I also have a 6" bungie cord to hook to it and to the rear rack frame to hold the chain guard up out of the way.  No need to remove the front bolt.  The bolt has a shoulder that prevents it from fully tightening down on the plastic chain guard to prevent crushing it.  This makes it possible to pivot the chain guard on the bolt without loosening it.
Offline jsonder
Reply #4 on: December 11, 2018, 02:42:12 AM
I remove the chain guard every time I replace a rear tire, chain, or sprocket(s).  I use the motion pro alignment guide to check rear wheel alignment after accessing any of those parts, so I need the chain guard to be removed.
https://www.youtube.com/watch?v=CAHSt_oV8jI
Offline sk8norcal
Reply #5 on: December 11, 2018, 05:21:33 AM
*Originally Posted by jsonder [+]
How do you remove the chain guard?
I removed the 2 bolts on the outside of the swingarm, but couldn't figure out the inside part.
Offline sk8norcal
Reply #6 on: December 11, 2018, 05:24:02 AM
*Originally Posted by Hillie [+]
I read some have cut the top rear half of the chain guard off for easier access.
Reply #7 on: December 11, 2018, 11:59:03 AM
Why don't you use the markings on the chain adjusters for alignment?
Reply #8 on: December 11, 2018, 03:56:24 PM
They are not accurate on my bike nor the other CB bikes I have worked on.
Reply #9 on: December 11, 2018, 08:05:45 PM
Many countries require a chain guard by law on bikes being sold for road use. Some actually require it for registration.
Considering that they are weak plastic, they aren't going to be all that good at protecting from a whipping chain , but they do stop crap being chucked everywhere, although almost of that will come from where the chain changes direction ( ie the two sprockets).
A guard will help reduce the probability of the chain smashing up the cases if it breaks, by guiding it to wrap around the CS and then out, but it isn't guaranteed.
Track bikes don't usually have them on, but the chains tend to be in perfect condition and less likely to break.
On off road bikes where there is large suspension travel they help to keep the chain on the sprockets on rough stuff.
So ...not necessary buit can be helpful. Not that hard to remove if you mod the front retainer for quick release.
