Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: False Neutral  (Read 1195 times)
  • City / Town: Bundaberg
Re: False Neutral
« Reply #10 on: December 14, 2018, 08:03:31 PM »
Most common cause of false neutral  or just not changing up, is the gear lever position. If it is too low it doesn't allow the shifter pawl to go back far enough to engage the next shifter pin. If too high it just go far enough upwards. Changing ridewear boots can have an effect , ifi it was OK to start with. Honda are notorious for it, because of their shift design. Properly adjusted they are fine, just finniky about position. If you have changed to a thicker boot it can have the same effect.
Offline Ceebixits500
  • Country: ie
  • What if we are NOT the culmination of evolution?
  • City / Town: Cork
Re: False Neutral
« Reply #11 on: December 14, 2018, 09:31:57 PM »
...... Honda are notorious for it, because of their shift design.....
That may be, but I have to give Honda full credit for whatever they have changed on the 2018 CB500X gearbox.
The way it slips into first gear from a stop is like a hot knife going into butter.
No jerk, no clunk, no jolt. Just a very positive, gentle meshing of teeth.
This pleases my sense of mechanical empathy  :152:
All other bikes I've ever owned have left me wondering when something in there was going to disintegrate.
But, amazingly, nothing ever did   :305:
Ceebixits
Re: False Neutral
« Reply #12 on: December 14, 2018, 10:50:48 PM »
I had a closer look at mine this evening, just out of interest (as you do...)
Anyway, there's a certain amount of lash in the linkage...I presumed it would be the rose joints, but it's actually wear between the lower spigot shaft and the hole in the shift pedal that the shaft locates in....
circled green in the pic below:
I don't have any real problems shifting but it can be a PIA to select 1st from time to time. This wear won't help, but it shouldn't be enough to cause shifting issues as things stand. However, it does make me think that a future upgrade might be in order, using better quality rod end bearings...and maybe a riv nut in the hole to beef the connection up a bit
« Last Edit: December 14, 2018, 10:59:13 PM by Jonathan »
Offline bdg
  • City / Town: Halifax
Re: False Neutral
« Reply #13 on: December 15, 2018, 03:26:04 PM »
Somewhat interesting short YouTube video on this topic from MC Garage:
Re: False Neutral
« Reply #14 on: December 15, 2018, 04:02:07 PM »
What you have circled shouldnt have any movement at all.  It is the end of the ball-post that the linkage ball-cap snaps onto.  The ball-post should be swagged into the shifter arm and be a solid attachment.  You probably need to replace your shifter arm.
I purchased a new gear shifter arm with the idea of shortening it.  But I finally found the right position after adjusting it several times and gave up on the idea of shortening it.  It is part number 24720-MGZ-305.  So, if you are interested in a replacement for cost of shipping, just shoot me a PM.
« Last Edit: December 15, 2018, 04:07:39 PM by SnowOwl »
Re: False Neutral
« Reply #15 on: December 15, 2018, 06:50:31 PM »
Thanks for the confirmation. :028: I thought as much when I looked at it. It's just under 10,000 miles so it hasn't faired very well...I'll see how much levers are going for and have a look at what else is available. If I can find some good quality rose joints I might try to strengthen the thing up a bit.
Re: False Neutral
« Reply #16 on: December 15, 2018, 07:22:58 PM »
one of these should do it...just need to check the thread size....it looks around M6, M5 without measuring
https://www.ebay.co.uk/itm/Stainless-Steel-Motorcycle-Gear-Link-M6-Ball-Socket-Joint-10mm-Right-Hand-HS/253245222204?epid=9008779740&hash=item3af6976d3c:g:1FoAAOSw6WFaAFEo
and the pivot end is crying out for a needle bearing or a bronze bush...come on Honda, sort it out
« Last Edit: December 15, 2018, 07:26:36 PM by Jonathan »
Re: False Neutral
« Reply #17 on: December 15, 2018, 07:36:59 PM »
Its a budget bike build to a budget standard...
Re: False Neutral
« Reply #18 on: December 15, 2018, 07:39:43 PM »
owned and ridden by budget people.... :080:
Offline Pocketpete
  • Bike: CB500X 2017
  • City / Town: Gee Cross
Re: False Neutral
« Reply #19 on: December 31, 2018, 12:14:13 PM »
My gearbox was odd when I got the bike gear changes were iffy.
These improved when I did my first oil change and put decent oil in.
As the bikes aged the gearbox has got smoother but I realised it changes so much better if you make sure you only touch the tip if the gear lever. Which can be difficult with big boots on.
Once you find the correct spot it's smooth and never gives me any problem.
