Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Keis Heated Gear Issue  (Read 1991 times)
Offline CalmBiker
  • Bike: CB500XA 2015
  • City / Town: Beverley
Re: Keis Heated Gear Issue
« Reply #10 on: December 22, 2018, 10:31:23 PM »
*Originally Posted by Irishrover [+]
Same style of connector that I have. It could be water ingress or not a clean connection. Try a dab of ACF50 or similar. Next time you are out and it switches off, try rotating the connector and see if it comes back on, if so that's the problem.
I bought mine for 60 on ebay a while back, so it doesn't owe me anything.
Mine was brand new and hasn't seen rain yet but it could easily have a broken wire perhaps.
Offline Tod.
  • Country: 00
  • Welsh, by the grace of God
  • City / Town: Basildon
« Reply #11 on: December 25, 2018, 08:48:58 PM »
I use a Keis heated body warmer. Also with oxford heated grips on my CB500X on a daily basis. Used with a heat controller, the vest only ever gets used in the lowest or sometimes in the mid position if really cold outside. Ive mistakenly knocked it back to the highest setting, and believe me, its too hot to ride. I had to stop to find out what was wrong. The bodywarmer has never switched itself off at any time. Even when it got too hot and uncomfortable. My power lead for the bodywarmer is connected directly to the battery with the supplied fused lead. Have you got he standard fused lead? Bit of a long shot, but change the fuse if all else fails, and make sure all connections are good and tight.
Offline CalmBiker
« Reply #12 on: December 26, 2018, 05:40:28 PM »
*Originally Posted by Tod. [+]
Thanks for the reply. Yes, exactly the same set up as you.
Offline andybeeone
  • Bike: cb500X MT-09 Tra
  • City / Town: Chesterfield
« Reply #13 on: January 15, 2020, 09:53:36 PM »
I had keis gear but too many problems made me ditch it. I now use warm and safe gear which is worn as a base layer so draws less power than keis. No problems so far. MUCH better imho
« Last Edit: January 15, 2020, 09:54:54 PM by andybeeone »
