Author Topic: Fork Gaiters for 2019 X?  (Read 2924 times)
Offline uku383
  • Bike: 2019 CB500XA
on: March 14, 2019, 10:26:59 PM
Hi All
I'm planning to buy a 2019 model, and want to put fork gaiters on immediately. Is anyone able to recommend a product or at least advise what size I should order?
I suspect that with the 19" front wheel, the size might be different to what people use for the 'series 1' bikes.
Thanks!
Graveyard: 2014 CB500XA
Offline terryboyle
  • Bike: looking at 2019X
Re: Fork Gaiters for 2019 X?
Reply #1 on: August 07, 2019, 03:24:20 AM
I have the same question. Any recommendations for sizing for a 2019?
Living the good life.
Reply #2 on: August 07, 2019, 04:04:44 AM
These are the ones I would recommend:
https://www.ebay.com/itm/2-New-Motorcycle-Fork-Gaiters-42x60x250mm-more-avail/390238349947
Same as all years - they fit the standard travel 17" front wheel bikes and the LEVEL 2 Rally-Raid bikes, while the 2019 bike is somewhere in the middle travel wise of course.
Last Edit: August 07, 2019, 04:13:59 AM by JMo
Offline terryboyle
Reply #3 on: August 07, 2019, 04:06:37 AM
Thank you for the speedy response
Offline Jamie Z
  • Bike: 2019 ABS
Reply #4 on: April 21, 2020, 08:15:31 PM
Thanks Jenny.
Bought these. Just installed them. Nice fit.
Offline LDesp
Reply #5 on: April 21, 2020, 10:04:36 PM
*Originally Posted by Jamie Z [+]
Thanks Jenny.
Any pics with the installed? Thanks  :062:
Offline Jamie Z
  • Bike: 2019 ABS
Reply #6 on: April 22, 2020, 01:01:37 AM
Here they are right after installation.
Looks like I might have to cut a vent in each one as they folded over after my first test ride from the pressure. Or maybe they’re too long and getting crushed. They are a bit on the long side, but it does look like they should work.
Jamie
Offline LDesp
Reply #7 on: April 22, 2020, 01:05:19 AM
Thanks for the pic they look good  :062:
Online CBRDEAN0
Reply #8 on: April 22, 2020, 10:07:48 AM
I did wonder if 250 long might be too much on std suspension.
The stock 2019 bike has 135mm of travel
add 20mm for the overlap of the fork lower
total 155mm
I would be looking for something between 170 and 200mm
Something like this
https://www.ebay.co.uk/itm/Short-FORK-GAITERS-42-x-60-x-80-200mm-NEW-Universal-for-BMW-K-BSA-Project/372061198700?hash=item56a093596c:g:EVkAAOSwo3xcb-Az
Reply #9 on: April 22, 2020, 07:31:57 PM
*Originally Posted by CBRDEAN0 [+]
total 155mm
Something like this
Yes, it's the 42/60mm dimension which is more important (to stop them dragging) - the 250mm length is primarily recommended for the longer travel L2 RR bikes (170mm travel).
As I recall someone also used some short gaiters for a Harley 883 sportster? and also a Triumph Bonneville in the past on standard travel bikes...
for info. 2019 bikes have 150mm travel (well, that's what the spec says - the measured swept distance is more like 141mm according to John who actually measured the 2019 damper rods), so a little longer than the stock 2013-18 travel bikes, which was 135mm.
What you don't want is them too short of course, otherwise at full extension there danger is they pop off the fork lowers (or drag down the stanchions).
Last Edit: April 22, 2020, 07:34:12 PM by JMo
