Author Topic: Under the seat toolkit  (Read 3149 times)
Offline nbsdave
  • Bike: 2018 500X, ABS
Re: Under the seat toolkit
Reply #10 on: April 16, 2019, 01:16:51 PM
good job and it seems you have most everything covered
there was a similar thread a while back but it died after promises to list a complete tool list were not forthcoming.
This makes up for it. Thanks for posting
Online ewryly
Reply #11 on: April 16, 2019, 01:48:39 PM
When you guys pump a tire using the portable pump, do you run the bike or leave it off? I usually carry cartridges, but I'm thinking of carrying a pump instead.
Offline 2Bpencil
  • Bike: 2016 CB500XA
Reply #12 on: April 16, 2019, 02:04:10 PM
 :046:
Thanks for posting- useful info, pics + feedback.
Online Twempie
Reply #13 on: April 16, 2019, 03:24:56 PM
Usually bike is off. YMMV.
BTW. Iíve had that pump for over 10 years, fused with a 7.5A.
Reply #14 on: April 16, 2019, 03:27:21 PM
*Originally Posted by nbsdave [+]
Hi NBSdave - everyone's choice is going to be slightly different depending on budget and/or what they already have in their tool stash, and they tend to evolve over time too - but if you use the search button on here it ought to lead you to those posts where people have described their own set-up.
For example, Twempie refers to the kit I put together when building up my bike a couple of years ago, and there is also a video of my packing set-up (including a list of the tools) here:
It's a slide show, so you need pause it if you want to read the lists in detail.
Hope that helps...
ps. there is also a [similar] list here as part of my ride report from the Trans-Am trip in 2015.
Last Edit: April 16, 2019, 03:28:47 PM by JMo
Reply #15 on: April 16, 2019, 03:47:39 PM
Following on from above, if anyone else is looking to condense their tools and other luggage as part of preparing for a longer-distance trail-biased trip on a CB500X, there is another great detail video from Juan Browne (Blancolirio on YouTube) where he goes through his packing list with various pros and cons - worth a watch:
Online Twempie
Reply #16 on: April 16, 2019, 03:50:08 PM
Jenny is more than correct. I searched all of her threads on this forum and ADV about what tools she carries, and made my toolkit based her experience. My kit is still incomplete, eg. tube repair (when I get a RR upgrade), zip ties, quick steel, tape and bodge fix items, etc.
Iím following her lead, all I did was read what she had to say and build my kitómostly with what I already had in the garage.
I will add that, while building the kit, I also checked to see what wrenches fit on which fasteners and made wheel removal tools a ďmust haveĒ.
Thanks Jenny.
Last Edit: April 16, 2019, 03:57:48 PM by Twempie
Online ewryly
Reply #17 on: April 16, 2019, 05:56:22 PM
*Originally Posted by Twempie [+]
Thanks, Twempie.
Online Twempie
Reply #18 on: April 17, 2019, 04:52:57 AM
Thatís a very helpful video. The RR rear solo rack looks like a smart option for the Coyote.
Offline mihai.i
  • Country: ro
Reply #19 on: March 19, 2020, 06:58:18 PM
I am also making a tool kit under my seat for a CB500x 2019. I have checked the bolts and nuts and so far this are the main wrench/socket sizes:
- 24 mm  and 19 mm rear wheel
- 19 mm and 14 mm allen key front wheel
- 10 mm and 12 mm rear wheel adjuster
- 14 mm and 12 mm clutch adjuster
- 14 mm engine mounts
- 4/5/6/8 mm different allen bolts
So far I haven't identified a 13mm or a 17mm bolt /wrench size.
I repeat, it's about a 2019 cb500x model.
