Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: CB500X 2019 what is maximum recommended power of auxiliary front LED?  (Read 564 times)
Offline cbvn
  • Country: vn
  • City / Town: Sai Gon
What is safe power of auxiliary front LED lights? For example is 2*30W still OK?
*Originally Posted by cbvn [+]
Yes, but only use the front blue wire to trigger a relay to power the lights, if that's your plan. You will need a fuse between the power source for the lights and the relay.
Offline cbvn
  • Country: vn
Thanks - OK, what about 2*60W? Is it possible for alternator which is rated 500W@5000rpm to handle such additional power?
I am thinking about two such lamps: https://www.aliexpress.com/item/32870349175.html
Yes, it should be fine. I am using about that much for my lights.
