Author Topic: 2019 Damper Rods In Pre-2018  (Read 3764 times)
Offline hondamxracer
on: June 23, 2019, 10:56:48 PM
Does anyone know if the 2019 damper rods which are 10mm longer can be installed in 2015 forks?
https://advrider.com/f/threads/honda-cb500x.840842/page-886#post-37853092
Last Edit: June 23, 2019, 10:59:35 PM by hondamxracer
Re: 2019 Damper Rods In Pre-2018
Reply #1 on: June 24, 2019, 10:01:12 AM
Yes they are a direct fit - I also suggest to use the matching springs from a '19 bike if you're not going for weight matched aftermarket linear springs. They (the 19 oem springs) are 5.5N/mm initially and have a much less harsh transition to the harder part at about 130mm travel (including preload) matching the damper rods much better than earlier springs.
Last Edit: June 24, 2019, 10:05:58 AM by Oyabun
Reply #2 on: June 24, 2019, 03:12:27 PM
I was thinking about pairing the 19 dampers with some race tech springs
Reply #3 on: June 24, 2019, 05:54:02 PM
*Originally Posted by hondamxracer [+]
for info. If you buy the 2019 LEVEL 1 fork kit from Rally-Raid, you'll get their 2019 length dampers, plus proper shim-valve damping and longer linear wound springs (which eliminate the crappy plastic spacer). You'd have a proper matched set-up then.
Reply #4 on: July 22, 2019, 12:52:51 AM
My 2019 springs and dampers will be in this week. Should i stick with the 10 wt oil?
I read that the stock oil level measurement (spring removed, damper installed, fork compressed) is 160mm. Would you recommend sticking with this?
Any idea how many CCs 160 measures out to?
Reply #5 on: July 22, 2019, 01:05:01 PM
I have mixed 10w and 15w fork oil for a roughly 12.5w viscosity. You'll need avout 470-ish ml per fork leg to get to about 160mm air gap.
Reply #6 on: July 22, 2019, 01:36:32 PM
What brand of oil are you using?
Reply #7 on: July 22, 2019, 02:00:29 PM
I'm using ENI in damper rod forks as that's what I have easy access to and have great performance/cost factor.
I tend t use Fuchs Silkolene in cartridge forks which I've found the best available, but that's quite a bit more expensive and harder to come by where I live.
Reply #8 on: July 24, 2019, 03:45:06 AM
Thanks!
I installed the 2019 dampers today. I can confirm you do get 10mm of rise.
I drained the oil from both fork legs into a ratio-rite measuring cup and both legs measured just under 450cc. Should I put 450cc back in or the 470cc noted above?
Last Edit: July 24, 2019, 03:48:32 AM by hondamxracer
Reply #9 on: July 24, 2019, 05:41:06 AM
Fill until you get about 160mm air gap.
